製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • High-Performance Processor: Powered by the Texas Instruments AM67A AI vision processor with four 64-bit Arm® Cortex®-A53 CPU cores up to 1.4 GHz, enabling robust AI, machine vision, and real-time automation capabilities.
  • AI Acceleration: Equipped with dual C7x DSPs and two Matrix Accelerators (MMAs) delivering up to 4 TOPS of deep learning performance, making it ideal for complex AI tasks.
  • Advanced Connectivity: Features high-speed PCIe, USB3 interfaces, and flexible multimedia I/Os, supporting cost-effective multi-camera and multi-display systems.
  • Rapid Prototyping: The 40-pin expansion header allows for solder-free system prototyping with countless compatible sensors, actuators, and connectivity add-ons, facilitating rapid development.
  • Customizable and Open-Source: Fully open-source design that allows professional and advanced users to modify hardware, optimizing supply chain management, manufacturing, and creating tailored derivatives.
仕様
Parameters
Processor
TI AM67A, Quad 64-bit Arm® Cortex®-A53 microprocessor subsystem at up to 1.4 GHz, multiple cores including Arm/GPU processors, DSP, and vision/deep learning accelerators up to 4 TOPS
RAM
4GB LPDDR4
Wi-Fi
Beagleboard BM3301, 802.11ax Wi-Fi
Bluetooth
Bluetooth Low Energy 5.4 (BLE)
USB Ports
4 x USB 3.0 Type A ports, supports 5Gbps operation
1 x USB 2.0 Type C, supports USB 2.0 device
Ethernet
Gigabit Ethernet, with PoE support (requires separate PoE HAT)
Camera/Display
1 x 4-lane MIPI camera/display transceivers
Display Output
1 x HDMI display
1 x OLDI display
Real-time Clock (RTC)
Supports external RTC battery for power failure time retention
Debug UART
1 x 3-pin debug UART
Power
5V/5A DC power via USB-C, with Power Delivery support
Power Button
On/Off included
PCIe Interface
PCI-Express® Gen3 x 1 interface for fast peripherals (requires separate M.2 HAT or other adapter)
Expansion Connector
40-pin header
Fan connector
1 x 4-pin fan connector, supports PWM speed control and speed measurement
Storage
microSD card slot, supports up to ultra high-speed SDR104 mode
Tag-Connect
1 x JTAG
1 x Tag-Connect for PMIC NVM programming (test and debug purposes only)
Board Dimension
85 x 56 x 20mm
ハードウェア概要
用途
  • Application
  • Robotics
  • Factory and Building Automation
  • Test & Measurement
  • Medical
  • Human-Machine Interfaces (HMIs)
  • Intelligent Vision (Image Classification/Object Detection/Semantic Segmentation)
認証
HSCODE8471504090
USHSCODE8517180050
UPC640265311062
EUHSCODE8471707000
COOCHINA
部品リスト
BeagleY®-AI Board
x1
Quick start card
x1
BeagleY®-AI
SKU 102991834
BeagleY®-AI is a high-performance single board computer powered by the Texas Instruments AM67A AI vision processor, delivering up to 4 TOPS of deep learning capability. Ideal for robotics, automation, and intelligent vision projects, it features extensive connectivity options and a 40-pin header for easy prototyping. Perfect for enthusiasts and professionals alike, BeagleY®-AI combines power and versatility in a compact, open-source design. Check more Beaglebone Hardware.
JPY¥11080.00
