製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Compact size 16x12 pixel IR thermal sensor array (MLX90641)
  • High FOV (field-of-view) of 55°x35° to capture more area
  • Wide temperature measurement range (-40℃~300℃)
  • I2C Grove interface for easy communication with an MCU
  • Fully calibrated IR array for convenient setup
This IR thermal camera carries a 16x12 array of thermal sensors (MLX90641) and it can detect the temperature of objects from far away with a center area accuracy of ±1℃ and average accuracy of ±1.5℃. In order to obtain the thermal images easily, the I2C protocol is used to get the low-resolution images from the camera. The FOV (Field of View) of this camera is 55°x35°, and the temperature measurement range is -40℃ to 300℃.
How Does Thermal Imaging Work?
All objects emit some amount of infrared radiation. This IR thermal imaging camera has a sensitive heat sensor that can detect tiny differences in temperature from the objects in the surrounding. Then it collects this radiation information from the objects and creates an electronic image that is based on the temperature difference information. The hotter an object is, the more infrared radiation it produces. However, this Infrared light is invisible to the naked eye and if the intensity is too high, it can be felt as heat.
This module can be connected to an MCU using the I2C interface. However, it needs an MCU that has over 20000 bytes of RAM to drive the camera. As a matter of fact, Dev boards like Arduino UNO cannot be used with this Sensor camera due to its lower ability of calculation. We recommend you choose Arch Mix as an MCU to control the camera because it really has an excellent performance to process the complex data from the IR sensor camera.
This Thermal Imaging Camera can be used to capture as follows:
Applications
  • High precision non-contact temperature measurements
  • Microwave ovens
  • Intrusion / Movement detection systems
  • Temperature sensing element for residential, commercial and industrial building air conditioning
  • Industrial temperature control of moving parts
  • Visual IR thermometers
Specifications
SpecificationDetails
Resolution16x12
FOV55°x35°
Measuring range-40℃ ~ 300℃
Refresh Rate0.5Hz ~ 64Hz
InterfaceI2C
Voltage3.3V-5V
Current~18mA
Parts List
1 x Grove - Thermal Imaging Camera - MLX90641 BCB 16x12 IR Array with 55° FOV
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping process. No jumpers or soldering required. We have developed more than 300 Grove modules, covering a wide range of applications that can fulfil a variety of needs. Not only are these open hardware, but we also have open-source software.
Note
For all Grove users (especially beginners), we provide you with the guidance of operation. Please read the instructions through the official website before your using the product.
認証
HSCODE9031900090
USHSCODE9031902100
UPC
EUHSCODE9013101000
COOCHINA
SKU 101020992
This IR thermal camera carries a 16x12 array of thermal sensors (MLX90641) and it can detect the temperature of objects from far away with a centre area accuracy of ±1℃ and average accuracy of ±1.5℃. In order to obtain the thermal images easily, the I2C protocol is used to get the low-resolution images from the camera. The FOV (Field of View) of this camera is 55°x35°, and the temperature measurement range is -40℃ to 300℃.
JPY¥7756.00
廃番
