製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Go from Module Selection to a Working Project
Discover how the Wio family supports your journey from early evaluation to real-world deployment, with setup guides, reference designs, SDKs, KiCad libraries, hands-on testing, and projects built by developers. Explore connectivity options across LoRa, Wi-Fi, BLE, GNSS, and more, then find the module and purchasing path that match your technical requirements, location, and development stage.
  • High-Speed Breakthrough:
The next-generation Semtech LR2021 not only retains the ultra-long-range communication of traditional LoRa but also introduces the new FLRC modulation, achieving a remarkable communication rate of up to 2.6 Mbps. This capability extends its use to bandwidth-sensitive applications, such as audio streaming and image transmission.
  • One Hardware, Global Coverage
With broad dual-band coverage (Sub-GHz & 2.4GHz) and the switch-less front end design, a single hardware design achieves global compatibility. Significantly streamline the design process and accelerating your market entry.
  • Univeral Platform
By integrating multiple modulation schemes (LoRa, FLRC, FSK, OQPSK) within a single silicon platform. LR2021 allows developers to choose the optimal combination for any scenario from ultra-low-power sensors to high-speed-controls without hardware redesign. Compatible with various low-power wireless protocols including Amazon Sidewalk, W-MBUS, Wi-SUN FSK, and Z-Wave, LR2021 enables true one-platform-fits-all development, dramatically reducing time-to-market and strategic risk.
  • Best-in-Class Energy Efficiency & Performance
LR2021 delivers a definitive generational leap, outperforming predecessors like the SX1262 across most key metrics. Lower transmission current and higher receiving sensitivity will translate directly into longer battery life and more reliable connections for your devices.
  • Enhanced Channel Activity Detection (CAD):
The LR2021 employs Fast CAD technology featuring an intelligent adaptive threshold and early termination mechanism, which substantially reduces both the power consumption and time required for idle channel detection, further improving device energy efficiency.
  • Ready-to-Go for Arduino, STM32 & Nordic DK
This integrated kit combines real-time OLED feedback and plug-and-play Grove connectors for rapid sensor integration. Its hardware is pin-compatible with Arduino Uno, STM32 Nucleo, and Nordic DK platforms, ensuring your validated design moves seamlessly to production.
Note:
Learn more about the next-generation performance of the Semtech LoRa Plus™ LR2021.
仕様
RF Chip Specification
Main Chip
LR2021
Chip Size
5(W)*5(L)*0.9(H)mm
Chip Package
QFN-48
Power Supply
1.8 - 3.7V, 3.3V (typical)
Sleep Current
470nA (without RTC)
1.28uA (with RTC)
Power Distortion Mode
SIMO DC-DC
LDO
Maximum Operating Current (Transmitter)
Sub-GHz: 105mA @ +22dBm
2.4 GHz: 27mA @ +14dBm
Maxium Operating Current (Receiver)
LoRa SF7 @ 125KHz: 5.7mA
FLRC: 10.9mA
Output Power
Sub-GHz: +22dBm to -10dBm
2.4 GHz: +12dBm
Receiving Sensitivity
LoRa SF12 @ 125kHz: -141.5dBm
FLRC @ 260kbps:-111dBm
BLE @ 2Mbps: -97dBm
Harmonic Noise
915MHz @ 100kHz: -104dBc/Hz
2.45GHz @ 100kHz: -93dBc/Hz
Antenna
RFI_LF(Sub-GHz)
RFI_HF(2.4GHz)
Impedence: 50Ω
Interface
SPI
Working Temperature
-40°C to +85°C
General
Board Size
65(W) x 73(L)mm x 27(H)mm
Voltage
3.3V (USB type-C)
Button
K1: User button
K2: Reset button
Display
0.96" OLED, 128 x 64 pixel
Grove Interface
I2C x 2
UART x 1
Debug Interface
SWD
SAMD
Antenna
Sub-GHz
2.4 GHz
ハードウェア概要
用途
  • Global Shipping and Logistics Tracking
Enable seamless global asset tracking. The LR2021 allows devices to automatically comply with regional radio standards, providing uninterrupted data from port to port.
  • Wireless Video & Image Transmission
With FLRC speeds up to 2.6 Mbps, LR2021 sends images within a second, enabling low-power visual monitoring for security, industrial, and environmental applications.
  • Audio Communication
LR2021 makes low-power audio communication practical—enabling safety intercoms on remote worksites, spoken alerts for equipment and voice-activated sensing in smart environments.
  • Converged Network
Unify dedicated short-range networks (for high-speed data collection) and wide-area networks (for continuous cloud connectivity) on a single device. This architectural shift eliminates redundant infrastructure.
  • High-Speed OTA for Critical Assets
LR2021's high-throughput link ensures robust and rapid firmware updates. It enables guaranteed, zero-downtime updates for critical infrastructure sensors.
認証
HSCODE8543709990
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Seeed Studio XIAO nRF54L15 Module
x2
LoRa Plus Expansion Board
x2
LF Antenna (490 MHz)
x2
HF Antenna (2.4 GHz)
x2
USB Cable Type-A Male to Type-C Male (1m)
x2
Read Me Note
x1
Semtech LR2021 LoRa Plus Evaluation Kit-CN490 | Semtech | LoRa | XIAO nRF54L15
SKU 100025096
This LR2021 LoRa® evaluation kit, centered on Semtech's 4th-generation dual-band transceiver, enables rapid prototyping of high-speed, long-range IoT devices. It supports Sub-GHz and 2.4GHz frequencies for global coverage, features FLRC modulation for data rates up to 2.6 Mbps, and is hardware-compatible with popular Arduino Uno, STM32 Nucleo, and Nordic DK platforms for seamless development.
JPY¥18835.00
