Product Details
Wiki & Learn
Reviews
Download PDF
Feature
  • Mobility & Dexterity:
Omnidirectional drive for agile navigation in tight spaces.
Feetech STS3215 servos (30kg torque/joint) for robust grasping and teleoperation.
  • Open & Modular:
Free hardware designs + code for customization (sensors, grippers, etc.).
Raspberry Pi/NVIDIA Jetson + LeRobot framework for remote control and flexible development.
  • Educational & Research-Ready:
Teaches robotics basics (kinematics, AI) via hands-on projects.
Records interaction data for machine learning model training.
Power Supply
12V Battery
Supported Controller
Raspberry Pi 5/ NVIDIA Jetson
Operating Temperature Range
0℃~40℃
Weight
1.7 kg
Dimension
300mm *300mm *230mm
Communication Protocol
UART
Servo Motor
Model
STS3215
Rated Input Voltage
12V
Rated Torgue
10KG.cm
Rated Current
900mA
Horn Type
25T/OD5.9mm
Gear Ratio
1/345
Hardware Overview
Application
The LeKiwi is designed to work with the LeRobot software platform, which provides:
Teleoperation
The LeKiwi supports multiple teleoperation methods:
  • Game controller input
  • Keyboard control (WASD for base movement)
  • Leader arm control (using a second SO-ARM101/100 as an input device)
Data Collection
The platform facilitates data collection for robotics research:
  • Joint angle recording
  • Camera feed capture
  • Task demonstration recording
Sensor Streaming
The system can stream sensor data to a laptop for:
  • More intensive processing
  • Visualization
  • System monitoring
For detailed information on software setup and integration with LeRobot, see Software Setup | SIGRobotics-UIUC/LeKiwi | DeepWiki.
Community Support
For questions or issues related to LeRobot integration, join the LeRobot's Discord server (channel mobile-so100-arm). The community can provide assistance with specific integration challenges. Check out community demos to discover more possibilities of LeKiwi: https://www.youtube.com/shorts/7WBpurj5Zoc
You can also leverage your LeKiwi components to the XLeRobot project —a dual-arm mobile robot designed for dynamic, household challenges. The transition is effortless: transfer your existing policies directly, with no need for motor ID changes or modifications to your single or dual-arm tabletop setup.
Discover more inspiring possibilities from the latest Seeed Embodied AI Hackathon!
Certification
HSCODE9023009000
USHSCODE9023000000
UPC
EUHSCODE9023001000
COOCHINA
Lekiwi 3D printed enclosure
x1
12V 4500 mAh Lithium Battery
x1
100mm Omnidirectional wheel
x3
Feetech STS3215 30KG Serial Servo
x3
Feetech Servo Cable
x3
DC-DC Buck Power Module - 12V to 5V
x1
DC Male to Dual DC Male 5521 Y-Cable
x1
USB Cable;Type C to Type A
x2
Plug Power Adapter;Black-12V-2A AC/DC
x1
Motor Control Board
x1
Stud(M2*6)
x2
Screw(M2*4)
x4
Screw(M3*16)
x32
Screw(M4*18)
x9
Screw(M2*6)
x12
Nut(M3*2.5)
x35
Screw(M3*18)
x6
Screw(M3*10)
x15
Stud(M3*45)
x6
Screw(M5*25)
x4
Nut(M5*3.5)
x4
LeKiwi Kit(12V Version) Mobile Base with 3D Printed Parts and Battery
SKU 114090065
LeKiwi Kit (12V version) Mobile Base is a low-cost, open-source, self-assembly mobile manipulator designed to empower educators, researchers, and makers with a versatile robotics platform. Developed by SIGRobotics-UIUC, this Mobile Base is compatible with raspberry pi 5 for running LeRobot, and integrates RGB USB cameras and 6-axis robotic arm (e.g.,LeRobot SO-ARM101/100) to enable precise navigation, object manipulation, and data-driven experimentation .
Note: This product includes only the LeKiwi mobile base. To get the full LeKiwi starter kit, we recommend adding the RGB camera (at least 2), Raspberry Pi 5, and SO-ARM101/100 as a bundle.
JPY¥28331.00
