おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Note
Please note that this sensor is factory-set to measure water density, if you have any requirements, please contact us at [email protected] to set the density like diesel or other mild-corrosive liquid.
It measures liquid levels ranging from 0 to 5 meters, making it widely applicable in industrial environmental sensing scenarios.
This sensor is with a waterproof aviation connector. It is compatible with SenseCAP Sensor Hub 4G Data Logger, which can collect various sensor data simultaneously and send them via 3G/4G LTE.
  • High Performance: High accuracy, fast response, and stability
  • Universal Protocol: MODBUS-RTU RS485
  • Wide-range Power Supply: Can be powered with supply voltage within 11V ~ 30V
  • Strong Robustness: Suitable to be immersed in water, oil, and other mild-corrosive liquid for a long time, anti-corrosion material, excellent anti-corrosion performance, and durable
  • Maintainance-Free: Anti-blocking design, easy to clean
The liquid level sensor measures the liquid level of mildly corrosive liquids such as water and oil. It is compatible with a data logger or other devices that support the RS485 Modbus-RTU protocol.
The liquid level sensor has a built-in high-performance and highly sensitive silicon piezoresistive core. The internal chip converts the sensor's millivolt signal into a standard protocol that can connect to a computer, control instrument, or PLC.
It's small-size, lightweight, and easy to install. It has a stainless steel sealing structure that can work in a corrosive environment. The sensor has high anti-vibration and anti-impact performance. It can be widely used in process control, aviation, aerospace, automobile, medical equipment, HVAC, and other applications.
Applications
  • Reservoir detection
  • Pool pump station
  • River monitoring
  • Marine monitoring
  • Dam and Lake monitoring
  • Sewage treatment
  • Deep well level monitoring
  • Tank level monitoring
Specifications
Measurement Range0 ~ 5 meters
Cable Length5.3 meters
Output SignalRS485 Modbus-RTU Protocol
Accuracy± 0.25%F.S
Zero Temperature Drift± 0.03%F.S/℃
Sensitivity Temperature Drift± 0.03%F.S/℃
Long-term Stability≤0.2%F.S/year
Response Time5ms( (≤90%F.S)
Measurement Liquid Slight corrosive liquid (water, edible oil, etc.)
Power Supply11-30V DC
Overload Capacity200%F.S
Compensation Temperature-10℃ ~ +70℃
Medium Temperature -40℃ ~ +80℃
Storage Temperature-40℃ ~ +85℃
Material
304 stainless steel shell,
316L stainless steel core,
special rubber-insulated cable.
IP RatingIP68
Device Weight670g
Certifications CE, FCC, RoHS
Technical Details
Wiring Diagram
Dimensions
認証
HSCODE9026100000
USHSCODE9026102080
UPC
EUHSCODE8517180000
COOCHINA
Industrial Liquid Level Sensor MODBUS RS485 Aviation Connector
SKU 101990860
An IP68 Liquid Level Sensor ranges - from 0 to 5 meters. Suitable for monitoring water, oil, and other mild-corrosive liquid levels. Use the sensor with Sensor Hub 4G data logger for seamless data collection and management.
USD$125.00
product.detail.alsoAdd.title
