The Global Positioning System (GPS) has proven its ability to locate people outdoors. Now, the use of Bluetooth beacons reduces power consumption and makes accurate, low-power indoor/outdoor positioning possible. Combined with SenseCAP T1000 Tracker ,it is possible to build an indoor/outdoor positioning solutions.
SenseCAP T1000 is a compact LoRaWAN® tracker that utilizes GNSS/Wi-Fi/Bluetooth for precise indoor & outdoor location tracking. It's ideal for a variety of location-based applications.
Deploy Bluetooth beacons in your target area, the tracker receives the signal sent by the beacon, and the positioning accuracy is at the meter level (2-3 meters). It can realize functions such as asset tracking, route planning, reverse car search, etc., and can be integrated into applets and APPs.
Material | ABS+PC |
Chip | nRF52 series |
IP rate | IP68 |
IK Rate | IK08 |
Dimension(LWH) | 115×100×29mm |
Weight | 169.1g(include battery) |
Battery | Lithium-ion battery, 4000mAh |
Battery life | More than 7 years (In default configuration). |
Working temperature | 40~85°C |
Working Humidity | 0~95%RH, no condensation |
Bluetooth Version | BLE 5.0 |
Bluetooth Protocol | iBeacon |
Broadcasting Power | -40~+4dBm |
Broadcasting Interval | 100ms~5s |
Broadcasting Distance | Up to 75 meters in open areas |
A rugged Outdoor Bluetooth Location Beacon for location-based services, asset tracking, navigation, and other applications, especially for SenseCAP T1000 Tracker and SenseCAP T2000 Tracker.
