Raspberry Pi Camera Module 3 NoIR is a compact camera from Raspberry Pi. It offers an IMX708 12-megapixel sensor with HDR, and features phase detection autofocus.
Raspberry Pi Camera Module 3 NoIR can be used to take full HD video as well as stills photographs, and features an HDR mode up to 3 megapixels. Its operation is fully supported by the libcamera library, including Camera Module 3’s rapid autofocus feature: this makes it easy for beginners to use, while offering plenty for advanced users. Camera Module 3 is compatible with all Raspberry Pi computers.
Camera Module 3 NoIR |
Focus range |
10cm –∞ |
10cm –∞ |
5cm –∞ |
5cm –∞ |
Focal length |
4.74mm |
4.74mm |
2.75mm |
2.75mm |
Diagonal field of view |
75 degrees |
75 degrees |
120 degrees |
120 degrees |
Horizontal field of view |
66 degrees |
66 degrees |
102 degrees |
102 degrees |
Vertical field of view |
41 degrees |
41 degrees |
67 degrees |
67 degrees |
Focal ratio (F-stop) |
F1.8 |
F1.8 |
F2.2 |
F2.2 |
Infrared-sensitive |
No |
Yes |
No |
Yes |
Parameter |
Detail |
Sensor |
Sony IMX708 |
Resolution |
11.9 megapixels |
Sensor size |
7.4mm sensor diagonal |
Pixel size |
1.4μm × 1.4μm |
Horizontal/vertical |
4608 × 2592 pixels |
Common video modes |
1080p50, 720p100, 480p120 |
Output: |
RAW10 |
Autofocus system |
Phase Detection Autofocus |
Dimensions |
25 × 24 × 11.5mm (12.4mm height for Wide variants) |
Ribbon cable length |
200mm |
Cable connector |
15 × 1mm FPC |
Compliance |
FCC 47 CFR Part 15, Subpart B, Class B Digital Device, Electromagnetic Compatibility Directive (EMC) 2014/30/EU, Restriction of Hazardous Substances (RoHS) Directive 2011/65/EU |
| Raspberry Pi Camera 3 NoIR | ×1 |
| HSCODE | 8525801390 |
| USHSCODE | 8525895050 |
| UPC | |
| EUHSCODE | 8517600000 |
| COO | UNITED KINGDOM |
