製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Raspberry Pi Camera Module 3 Wide NoIR is a compact camera from Raspberry Pi, presenting 120 degrees Diagonal FOV. It offers an IMX708 12-megapixel sensor with HDR, and features phase detection autofocus.
Feature
  • Raspberry Pi Camera Module Third Generation: Back-illuminated and stacked CMOS 12-megapixel image sensor (Sony IMX708) with HDR for up to 3 megapixel output
  • High-quality Image Output: 4608 × 2592 pixels, along with built-in 2D DPC and QBC Re-mosaic function, offering high SNR
  • Wide Field of View: 120 degrees Diagonal field of view, offer 102 degrees horizontal field of view and 67 vertical field of view
  • Autofocus System: Phase detection autofocus
  • CSI-2 serial Data Output: 2-wire serial communication, supporting I2C fast mode and fast-mode plus
Raspberry Pi Camera Module 3 Wide NoIR can be used to take full HD video as well as stills photographs, and features an HDR mode up to 3 megapixels. It presents 120 degrees Diagonal field of view, where 102 degrees horizontal field of view and 67 vertical field of view.
Its operation is fully supported by the libcamera library, including Camera Module 3’s rapid autofocus feature: this makes it easy for beginners to use, while offering plenty for advanced users. Camera Module 3 is compatible with all Raspberry Pi computers.
Raspberry Pi Camera Module 3 Series Comparison
Camera Module 3
Camera Module 3 NoIR
Focus range
10cm –∞
10cm –∞
5cm –∞
5cm –∞
Focal length
4.74mm
4.74mm
2.75mm
2.75mm
Diagonal
field of view
75 degrees
75 degrees
120 degrees
120 degrees
Horizontal
field of view
66 degrees
66 degrees
102 degrees
102 degrees
Vertical
field of view
41 degrees
41 degrees
67 degrees
67 degrees
Focal ratio
(F-stop)
F1.8
F1.8
F2.2
F2.2
Infrared-sensitive
No
Yes
No
Yes
Application
  • High quailty monitor
  • Learning camera
  • Image capture for AI applications
Parameter
Detail
Sensor
Sony IMX708
Resolution
11.9 megapixels
Sensor size
7.4mm sensor diagonal
Pixel size
1.4μm × 1.4μm
Horizontal/vertical
4608 × 2592 pixels
Common video modes
1080p50, 720p100, 480p120
Output:
RAW10
Autofocus system
Phase Detection Autofocus
Dimensions
25 × 24 × 11.5mm (12.4mm height for Wide variants)
Ribbon cable length
200mm
Cable connector
15 × 1mm FPC
Compliance
FCC 47 CFR Part 15, Subpart B, Class B Digital Device, Electromagnetic Compatibility Directive (EMC) 2014/30/EU, Restriction of Hazardous Substances (RoHS) Directive 2011/65/EU
Raspberry Pi Camera 3 Wide NoIR×1
Is there any size differences between the Raspberry Pi Camera Module 2 and Raspberry Pi Camera Module 3?
  • The PCB size and mounting holes remain the same as for Camera Module 2.
  • The Z dimension differs: due to the improved optics, Camera Module 3 is several millimetres taller than Camera Module 2
認証
HSCODE8525801390
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOUNITED KINGDOM
Raspberry Pi Camera Module 3 Wide NoIR - Sony IMX708, 4608 × 2592 pixels, 120 degrees Diagonal FOV, autofocus
SKU 114993031
JPY¥5540.00
