おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • 3 MP Sony IMX500 Intelligent Vision Sensor
  • Integrated on-board inferencing acceleration for common neural network models, enabling complex vision AI applications without additional accelerators
  • Tightly integrated with the Raspberry Pi camera software stack, allowing users to easily deploy their own neural network models
  • Support for tensor metadata in the libcamera and Picamera2 libraries, and in the rpicam-apps application suite, making it easy for beginners to use while offering advanced users unparalleled power and flexibility
  • Integrated RP2040 for neural network firmware management
  • Works with all Raspberry Pi models, using the standard camera connector cable
仕様
Parameter
Sensor
Sony IMX500
Resolution
12.3 megapixels
Sensor size
7.857 mm (type 1/2.3)
Pixel size
1.55 μm × 1.55 μm
Horizontal/vertical
4056 × 3040 pixels
IR cut filter
Integrated
Autofocus system
Manual adjustable focus
Focus range
20 cm – ∞
Focal length
4.74 mm
Horizontal field of view
66 ±3 degrees
Vertical field of view
52.3 ±3 degrees
Focal ratio (F-stop)
F1.79
Infrared sensitive
No
Output
Image (Bayer RAW10), ISP output (YUV/RGB), ROI,
metadata
Input tensor maximum size
640(H) × 640(V)
Input data type
'int8' or 'uint8'
Memory size
8388480 bytes for firmware, network weight file,
and working memory
Framerate
2×2 binned: 2028×1520 10-bit 30fps
Full resolution: 4056×3040 10-bit 10fps
Dimensions
25 × 24 × 11.9 mm
Ribbon cable length
200 mm
Cable connector
15 × 1 mm FPC or 22 × 0.5 mm FPC
Operating temperature
0°C to 50°C
Compliance
For a full list of local and regional product approvals,
please visit pip.raspberrypi.com
Production lifetime
The Raspberry Pi AI Camera will remain in production until
at least January 2028
ハードウェア概要
Physical specification
用途
認証
HSCODE8525891900
USHSCODE8525895050
UPC
EUHSCODE8517600000
COOJapan
部品リスト
x1
CSI cable (15-pin for Pi 2/3/4)
x1
CSI cable (22-pin for Pi Zero/Pi 5)
x1
Lens adjustment tool
x1
SKU 102111006
The Raspberry Pi AI Camera is a compact, powerful module featuring a 12MP Sony IMX500 sensor with on-board AI acceleration, enabling users to develop sophisticated vision-based applications without a separate accelerator.
JPY¥11080.00
廃番
product.detail.alsoAdd.title
