製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Raspberry Pi All in One Board: Powered by RPi CM4 32GB, integrated with IPS multi-touch screen, dual-band Wi-Fi & Bluetooth, pre-installed compatible Linux system
  • Modular Design: Featuring high-speed expansion interface and 40-Pin Raspberry Pi compatible header, and official Seeed expansion board
  • Rich Interfaces & Components: Equipped USB Type-A ports, Gigabit Ethernet, micro-HDMI, micro-SD card slot, MIPI camera interface, light sensor, accelerometer, buzzer, RTC and programmable buttons
  • Neat Personal Assistance: Enjoy yourself in multiple interested Dashboard or AI projects by Seeed and communities while utilizing built-in sensors and components
Note: Product Lifetime:at least until 2034 (Based on Raspberry Pi)
仕様
Details
Platform
Processor
Broadcom BCM2711 quad-core Cortex-A72 (ARM v8)
Frequency
64-bit SoC @ 1.5GHz
Memory
Capacity
4GB
Technology
LPDDR4 with on-die ECC
eMMC
Capacity
32GB
Wireless
Wi-Fi
2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac
Bluetooth
Bluetooth 5.0, BLE
Display
LCD
5-inch 720x1280 LCD
Touch Panel
Capacitive touch panel (support multi-touch)
Video
HDMI
1 x Micro HDMI output (up to 4Kp60 supported)
CSI
1 x 2-lane MIPI CSI camera interface
Multimedia
H.265 (4Kp60 decode)
H.264 (1080p60 decode,1080p30 encode)
OpenGL ES 3.0 graphics
Built-In Modules
Real-Time Clock
NXP Semiconductors PCF8563T
Low backup current; typical 0.25μA at VDD = 3.0 V and Temperature = 25 ℃
Accelerometer
STMicroelectronics LIS3DHTR
16-bit, ±2g/±4g/±8g/±16g dynamically selectable full scale
Encryption
Microchip ATECC608A
Secure Hardware-Based Key Storage, Asymmetric Sign, Verify, Key Agreement
Light Sensor
Levelek LTR-303ALS-01
Digital light sensor
Internal IO
Expansion
Microchip MCP23008-E
Buzzer
≥85dB @10cm 2700±300Hz
External I/O
GPIOs
Up to 5 × UART
Up to 5 × I2C
Up to 5 × SPI
1 × SDIO interface
1 × DPI (Parallel RGB Display)
1 × PCM
1 × PWM channel
Up to 3× GPCLK outputs
Vertical expansion
interface
1 × PCIe 1-lane Host, Gen 2 (5Gbps)
1 × USB 2.0 port (highspeed)
26 x GPIOs
POE
Power
Voltage
5V DC
Current
3A(Minimum)
Temperature
Operating Temperature
0 - 70°C( For the LCD Screen: 0 - 60°C)
Mechanical
Dimensions
140mm x 95mm x 21mm
Weight
285g
Certification
Certificates
CE, FCC, TELEC(211-210815)
ハードウェア概要
Note
Before you attach a camera with the CSI 22 Pin cable to the board, please double-check the FFC contact pins are facing up.
用途
The reTerminal can be your personal useful development board since it is built around Raspberry Pi CM4 module, and it provides multiple function thanks to its unique modular design and rich interfaces. You will find it more interesting when you discover there are plenty of skillful IoT & AI projects published by Seeed and the community.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reTerminal CM4104032
x 1
Screw driver
x 1
reTerminal CM4104032 - AI, IoT, IIoT Human Machine Interface, All-in-one Board, Modular Design, RPi CM4 32GB powered, IPS multi-touch screen, 2.4GHz/5GHz Wi-Fi & Bluetooth 5.0, rich interfaces
SKU 110070048
The reTerminal is a Human-Machine Interface facility, designed in modularization, offering multiple interfaces and components. It is your hand-sized, powerful, Raspberry Pi-based all-in-one board, assisting you to develop individual IoT & AI projects and being ready to materialize monitor and control functions as you need.
Model
Display Size
RAM
eMMC
JPY¥46770.00
廃番
Customize Design recomputer
