おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Rugged design for harsh working environment: IP65 front panel, -10~50°C operating temperature
  • Open-source design in software and hardware: Powered by Raspberry Pi CM4, easy for customization or derivatives with the PCIe extensions design (flexible for NVME SSD, Dual 1000M Ethernet, Dual USB 3.0, COM Port RS485/232, and more customizations)
  • Cost-effective Device Master: HMI, PLC, Panel PC and gateway all-in-one. Perfect for the distributed hub devices
  • Low code programming for event-driven applications: Natively integrated Node-RED for flow-based editing and one-click deployment, compatible with all software runs on Raspberry Pi
  • Hybrid connectivity: Support 4G LTE, LoRaWAN®, Wi-Fi, BLE, RS485/RS232, CAN bus, 1000M Ethernet, USB, HDMI
  • Product Warranty: Two-year warranty
Note: Product Lifetime: at least until 2034 (Based on Raspberry Pi)
仕様
Basic
CPU
CM4 Quad-core Cortex-A72@ 1.5GHz
Memory
8GB
Storage
32GB eMMC
M.2 NVMe SSD Slot 2280-M Key (optional)
OS Support
Raspbian
SenseCraft Edge OS
Display
Size
10.1''
Max. Resolution
1280 x 800
Max. Colors
16.7M (8-bit)
Luminance (nit)
400
Viewing Angle (H/V°)
170/170
Backlight Life (hrs)
30000
Touch Type
10-point Capacitive
Pencil Hardness
7H
Video&Audio
Video
HDMI2.0
Audio
2 x Microphone
Buzzer
3.5mm Audio Jack
Camera
CSI (optional)
Interfaces
Ethernet
1 x 10/100/1000 Mbps
2 x 10/100/1000 Mbps (optional)
USB
2 x USB-A 2.0 Host
RS485
1 x RS485 > Terminal Block
1 xRS485 > DB9 (optional)
RS232
1 x RS232 > Terminal Block
1 x RS232 > DB9 (optional)
CAN
1 x CAN-BUS > Terminal Block
DI
4 x DI > Terminal Block
DO
4 x DO > Terminal Block
40pin GPIO
Inside
Wireless Communication
Wi-Fi
On-chip Wi-Fi
BLE
On-chip BLE
LoRa®
Mini-PCIe for LoRaWAN® (optional)
Cellular
Mini-PCIe for 4G (optional)
Power
Input
2-pin Terminal Block
PoE
12.95W PoE (optional)
Power Range
12~24V DC
Power Consumption
6W Typ.
9W Max.
Power Switch
NO
Reboot Switch
YES
Environment
Ingress Protection
IP65 Front Panel
Operating Temperature
-10~50 °C
Storage Temperature
-20~70 °C
Humidity (Operating)
10~95% RH
Mechanical
Dimension (W x H x D)
259.4 x 191 x 42.2 mm
Enclosure
Die-cast Aluminum Alloy
Mounting
Panel, VESA, DIN-rail
Weight (Net)
1.8Kg
Vibration Resistance
5 Grms random vibration (5 ~ 500Hz) during operation, IEC60068-2-64
Shock Resistance
Operating 50 G peak( 11ms duration), IEC 60068-2-27
Certification
CE, FCC, UCKA, RoHS, TELEC, REACH
EMC
ESD
EN61000-4-2, Level 3
EFT
EN61000-4-4, Level 2
Surge
EN61000-4-5, Level 2
Others
RTC
High Accuracy RTC (with a CR2032 battery)
Hardware WatchDog
1~255s
Security
ATECC608A
Warranty
2 Years
Heat Dissipation
Fanless
ハードウェア概要
reTerminal DM is an integrated device master that can function as an HMI/PLC/Gateway/Panel PC all-in-one device, working in the edge layer of the IOT architecture, unifying data flow, and managing onsite devices, reducing the big gap between legacy systems and modern IT infrastructures in various application scenarios.
用途
The reTerminal DM HMI presents a versatile solution applicable across numerous industries. Seamlessly integrating cutting-edge technologies, it streamlines operations and enhances efficiency. Running on the Home Assistant platform and employing Computing Vision, Cloud solutions, and platforms like N3uron, Ignition Edge, and Node-RED, along with our proprietary platform, Sensecraft Edge OS, it opens up exciting possibilities for developers and enthusiasts alike.
  • Energy Management: Monitor grids, monitor and maintain solar panels.
  • Building Management: Central control panel for BAS, individual room control panels.
  • MedTech: Medical device control panel, patient monitoring station.
  • Construction: BIM, Monitor sites, control heavy machinery.
  • Transportation: Monitor vehicle health, control ticketing systems (buses, trains).
  • Agriculture:  Control irrigation systems, monitor greenhouse conditions.
  • Retail:  Display digital signage, control self-checkout kiosks.
  • Logistics: Track inventory movement, manage warehouse operations.
  • Water Management: Monitor water treatment plants, control water distribution.
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reTerminal DM Panel PC x 1
20-pin Terminal Block Connector(Male) x 1
2-pin Power Female Jack to
Screw Terminal  Adapter
 x 1
Screw Pack x 1
Fuse x 1
User Guide x 1
Wi-Fi/BLE feeder cable(installed) x 1
Wi-Fi/BLE Antenna x 1
reTerminal DM - 10.1'' HMI| CM4108032 | Raspberry Pi Rugged Panel PC | Panel Controller
SKU 114070201
reTerminal DM is a Panel PC, HMI, IIoT Gateway all-in-one device powered by Raspberry Pi CM4, with 10.1'' IP65 front panel and supports Raspberry Pi-based software ecosystem.It is equipped with rich interfaces, supporting CAN bus, RS485, RS232, Gigabit Ethernet, as well as powerful wireless communication capabilities such as 4G, LoRa®, Wi-Fi, and BLE.
Model
Display Size
RAM
eMMC
JPY¥73488.00
¥81654.00
Save ¥8166.00(10%)
product.detail.alsoAdd.title
