製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Alternative Charging Modes: Supply by UPS-18650 dual chargeable battery, DC jack, and PoE function
  • Multiple Wireless Communication: Provide LoRaWAN/LTE/4G/5G all four data transmission abilities with antennas
  • Onboard Industrial Interface: Support RS-485, RS-232, and CAN Bus high-speed connection
  • Onboard Massive Storage: Available card slot supporting SSD with M.2 B KEY, SATA 2.0
  • Onboard Audio Capability: Equip with two microphones and one speaker for expandable Al-powered capabilities
仕様
Parameter
Remark
Power
DC Jack
DC 12V @4A
The DC Jack or PoE power supply should be prioritized.
PoE
25W (as powered device).
UPS
2 x Battery holder for 18650 battery(optional)
The battery will automatically stop charging if it is overheat, and LED2 will flash.
Interface
1 x RS485
6 Pin Terminal Connector
a maximum communication rate of 256000 baud
1 x RS232
DP9 connector
1 x CAN
CAN supports a 500KBps communication rate at common mode and supports the communication rate up to 8Mbps at FD mode.
1 x RJ45
Equips with LAN7800 IC supports PoE module
Ethernet supports maximum gigabit rates, but the LAN7800 driver is required
1 x Connector
100 pins Industrial High-Speed Interface
Connect with reTerminal through 100 pins high-speed interface
Indicators
3 x LEDs
Components
Microphone
Two Analog Microphones
Speaker
8Ω/1W
Fan
3-Pin Fan
Supports speed control and speed measurement
Antenna holes
4 x Antenna holes
supports multiple wireless communication protocols
Wireless Connection
M.2 solt supports 4G/5G modules and M.2 NVMe SSD
compatible with SIMCOM 8052 5GCompatible with B key SSD
suitable for 2242/2280
Mini-PCIe slot supports LTE/4G/LoRaWAN modules
compatible with EC25/EC20, LoRaWAN module suggested Seeed WM1302
SIM card slot supports LTE/4G/5G
The SIM card only supports mini-pcie or M.2 devices at one time and it can be toggled by the switch on the board
Dimension
140mm x 95mm x 30mm
ハードウェア概要
Accessories Information
Note
Product Name
Remarks
Power cable
DC 12V @4A
Full power consumption requires a 4A power supply, but sometimes partial 2A/3A power supply can also support
Battery
18650
Panasonic NCR18650B 3.6V 3400mAh recommended
SSD
M.2 SSD 2242/2280
M.2 B key (SATA)
4G module
EC25/EC20
Tested with Quectel (manufacturer)
5G module
SIM8202G
Tested with Simcom (manufacturer)
Wio Module
WM1302 LoRaWAN Gateway Module (USB/SPI) US/EU
WM1302 LoRaWAN Gateway Module(USB) - EU868, based on SX1302 - Seeed Studio
用途
  • Agriculture: Crop monitoring, insect alarm, LoRa/LTE/5G wireless communication
  • Home: Home monitoring, security alarm, power-off supported
  • Individual: Mobile-Human Machine Interaction computer
認証
HSCODE8543909000
USHSCODE8543903500
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
reTerminal E10-1 - Expansion Board
x1
Screw Driver
x1
reTerminal E10-1 - Expansion Board supports DC Jack/PoE/UPS, Gigabit Ethernet, LTE/4G/5G/LoRaWAN, RS485/232, CAN, SATA 2.0
SKU 103060001
The reTerminal E10-1 expansion board supercharges your reTerminal with rechargeable power, upgraded wireless connectivity, versatile data transmission, and audio support. It’s all about flexibility, letting you tailor your setup for everything from maker projects and rugged home automation builds to off-grid DIY experiments. Head to the wiki to unlock more possibilities.
Model
Display Size
RAM
eMMC
JPY¥18835.00
