製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Fast boot times and smooth overall experience: Powered by Raspberry Pi Compute Module 4 and 4GB RAM/32GB eMMC
  • Compact and highly integrated: 75x64x21mm in size, with dual Gigabit Ethernet ports and dual USB3.0 ports
  • Highly scalable with rich IO peripherals: dual Gigabit Ethernet connectors, Micro-SD card slot, micro-HDMI interface, USB 3.0, MIPI CSI, MIPI DSI, etc.
  • Easy to deploy with stability: DIN rail mount and keyhole slot allow you to hang it anywhere
  • Pre-installed OpenWRT firmware: Out of the box, can easily implement software router applications
  • Customization Supported: Contact [email protected] for your customization needs
仕様
Carrier Board
Details
Networking
Dual Gigabit Ethernet Connectors
USB 3.0 to GbE
(Gigabit Ethernet Bridge)
Microchip's LAN7800
USB
2 x USB 3.0 Ports
1 x USB 3.0 9-Pin Header
Storage
Micro-SD Card Slot (load system Image for non-eMMC CM4 version)
Camera
1 x MIPI CSI Connector
Display
1 x MIPI DSI Connector
1 x Micro HDMI Connector
FPC
Interface for I2C and SPI
External Fan
Power connector for fan
Power
5V/3A using USB Type-C Port
LAN7800 Industrial
Temperature Range
-40°C to +85°C
Dimensions
75x64x21mm
Weight
43g
Compute Module 4
Details
Processor
Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
Memory
4GB LPDDR4
Storage
32GB eMMC
Connectivity
2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac Wi-Fi, Bluetooth 5.0, BLE with onboard and external antenna options
Onboard Gigabit Ethernet PHY supporting IEEE1588
1 × USB 2.0 interface
PCIe Gen 2 x1 interface
28 GPIO signals
SD card interface for SD card or external eMMC
Video
Dual HDMI interface (up to 4Kp60 supported)
2-lane MIPI DSI display interface
2-lane MIPI CSI camera interface
4-lane MIPI DSI display interface
4-lane MIPI CSI camera interface
Multimedia
H.265 (4Kp60 decode); H.264 (1080p60 decode, 1080p30 encode); OpenGL ES 3.0 graphics
Input power
5V DC
Operating temperature
0 to +80°C
Dimensions
55 mm × 40 mm
Production lifetime
Raspberry Pi Compute Module 4 will remain in production until at least January 2034
Compliance
Full list of local and regional product approvals
ハードウェア概要
用途
  • Software Router
  • IoT applications
  • Smart Home
  • Camera / Video-related Projects
認証
HSCODE8471419000
USHSCODE8517620020
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4 with 4GB RAM, 32GB eMMC
1
Aluminum Case
1
International Wall Adapter Power Supply 5VDC 4A – Type-C (with US/AU/UK/EU plugs)
1
reRouter CM4 1432 - Raspberry Pi Based Mini Router, Travel Router, Dual Gigabit Ethernet, OpenWRT OS
SKU 110110110
The Mini Router is pre-installed Seeed's custom OpenWRT system, the hardware is equipped with dual Gigabit Ethernet ports and dual USB 3.0 ports, as well as a Raspberry Pi Compute Module 4 with 4GB RAM and 32GB eMMC. The full system makes it suitable for soft router applications while keeping the hardware to a minimum. Discover More Raspberry Pi Powered Edge HMI, Controller, and Edge IoT Devices.
JPY¥38999.00
Customize Design reRouter
