おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Fast boot times and smooth overall experience: Powered by Raspberry Pi Compute Module 4 and 2GB RAM/32GB eMMC
  • Compact and highly integrated: 75x64x21mm in size, with dual Gigabit Ethernet ports and dual USB3.0 ports
  • Highly scalable with rich IO peripherals: dual Gigabit Ethernet connectors, Micro-SD card slot, micro-HDMI interface, USB 3.0, MIPI CSI, MIPI DSI, etc.
  • Easy to deploy with stability: DIN rail mount and keyhole slot allow you to hang it anywhere
  • Pre-installed OpenWRT firmware: Out of the box, can easily implement software router applications
  • Customization Supported: Contact [email protected] for your customization needs
仕様
Carrier Board
Networking
Dual Gigabit Ethernet Connectors
USB 3.0 to GbE
(Gigabit Ethernet Bridge)
Microchip's LAN7800
USB
2 x USB 3.0 Ports
1 x USB 3.0 9-Pin Header
Storage
Micro-SD Card Slot (load system Image for non-eMMC CM4 version)
Camera
1 x MIPI CSI Connector
Display
1 x MIPI DSI Connector
1 x Micro HDMI Connector
FPC
Interface for I2C and SPI
External Fan
Power connector for fan
Power
5V/3A using USB Type-C Port
LAN7800 Industrial
Temperature Range
-40°C to +85°C
Dimensions
75x64x21mm
Weight
43g
Compute Module 4
Processor
Broadcom BCM2711 quad-core Cortex-A72 (ARM v8) 64-bit SoC @ 1.5GHz
Memory
2GB LPDDR4
Storage
32GB eMMC
Connectivity
2.4GHz and 5.0GHz IEEE 802.11b/g/n/ac Wi-Fi, Bluetooth 5.0, BLE with onboard and external antenna options
Onboard Gigabit Ethernet PHY supporting IEEE1588
1 × USB 2.0 interface
PCIe Gen 2 x1 interface
28 GPIO signals
SD card interface for SD card or external eMMC
Video
Dual HDMI interface (up to 4Kp60 supported)
2-lane MIPI DSI display interface
2-lane MIPI CSI camera interface
4-lane MIPI DSI display interface
4-lane MIPI CSI camera interface
Multimedia
H.265 (4Kp60 decode); H.264 (1080p60 decode, 1080p30 encode); OpenGL ES 3.0 graphics
Input power
5V DC
Operating temperature
0 to +80°C
Dimensions
55 mm × 40 mm
Production lifetime
at least January 2034
Compliance
Documents - Product Information Portal - Raspberry Pi
ハードウェア概要
用途
  • Software Router
  • IoT applications
  • Smart Home
  • Camera / Video-related Projects
認証
HSCODE8517623600
USHSCODE8517620020
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4 with 2GB RAM, 32GB eMMC
x1
Aluminum Case
x1
International Wall Adapter Power Supply 5VDC 4A – Type-C (with US/AU/UK/EU plugs)
x1
reRouter CM4 102032 - Raspberry Pi Based Mini Router, Travel Router, Dual Gigabit Ethernet, OpenWRT OS
SKU 110110205
The Mini Router is pre-installed with a custom OpenWRT system and equipped with dual Gigabit Ethernet ports, dual USB 3.0 ports, and a Raspberry Pi Compute Module 4 with 2GB RAM and 32GB eMMC. The full system makes it suitable for soft router applications while keeping the hardware to a minimum. Discover More Raspberry Pi Powered Edge HMI, Controller, and Edge IoT Devices.
USD$165.20
$206.50
Save $41.30(20%)
product.detail.alsoAdd.title
Customize Design reRouter
