製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Dual Gigabit Ethernet NICs Carrier Board is a compact size board, that has been integrated Dual Gigabit Ethernet connectors and multiple peripherals, designed for miniature customizable network router applications, suitable for HTPC makers, Linux developers, software router enthusiasts, and the majority of regular Raspberry Pi users.
  • Dual Gigabit Ethernet Carrier Board for Raspberry Pi CM4: Provide dual gigabit ethernet connectors based on CM4 for customizable network router applications
  • Integrated Peripherals in Compact Size: 75x64x21mm size overall, integrated two USB 3.0 standard connectors with an additional 9-pin header, one micro-HDMI interface, and one Type-C power supply
  • Rich Components on the board: Provide MIPI CSI/ MIPI DSI for the camera, FPC connector for I2C & SPI, alone with UART IO, a 4-pin fan connector, and one Micro-SD Card Slot
This is the Raspberry Pi Compute Module(CM4) carrier board, which has been integrated with Dual Gigabit Ethernet connectors, along with two USB 3.0 standard connectors and other peripherals in the compact size. With additional components on the board, it can be your perfect choice for a miniature customizable network router that performs high flexibility and security.
The Dual Gigabit Ethernet connectors on this board can be used to manage the network by your definition, referring to the use of open-source operating systems to form a routing solution, leveraging the 1Gbps speed for both ports. Unlike specialized routers designed by manufacturers, you can utilize OpenWrt, one of the open-source operating systems to build and manage your own local network.
It features a variety of components in the compact size, where it provides MIPI CSI/ MIPI DSI connectors for camera support, an FPC connector for I2C & SPI communication, one 4-pin fan connector for heat suppression, along with 4 UART IO for further usage. It is even equipped with one Micro-SD Card Slot for booting the system from the SD card, in the case, there is no eMMC storage on the Raspberry Pi CM4.
What is a Router?
A router is a piece of hardware that connects a Local Area Network (LAN) to other networks, which is mostly known as a Wide Area Network (WAN). The router is the pivot of this local network that it manages all the connected devices in LAN. Its main function of it is coordinating connections and forward data between LAN and WAN.
If you want to use the carrier board to build a Raspberry Pi Router, you can refer to this tutorial.
Seeed has provided some Mini Servers that you might be interested in:
  • ODYSSEY - X86J4105 allows you to simply build Edge Computing applications with powerful CPU and rich communication interfaces.
  • ZimaBoard 832 model is a low-cost single board server equipped with Intel Celeron N3450 Quad Core working distinguishingly as a 4T free charge cloud server or a 4K display media server.
Application
  • Home Theater PC(HTPC)
  • Security Home Router
  • Private Network
  • VPN
  • Offline Download
  • Advertising Block
  • QOS
  • Traffic Control
  • Multi-Line Control
  • Link Load Balancing
Practical Tools Utilization
Open-Source Wireless Router: OpenWrt
OpenWrt is an open-source soft router for embedded operating systems based on Linux, primarily used on embedded devices to route network traffic. It offers more features, performance, and security than a traditional router where it has a filesystem that’s fully writable and includes a package management system.
You can flash OpenWrt firmware after attaching a Compute Module 4 to this board and turn this board into a software router!
Specifications
SpecificationDetails
NetworkingDual Gigabit Ethernet Connectors
USB 3.0 to GbE
(Gigabit Ethernet Bridge)
Microchip's LAN7800
USB2 x USB 3.0 Ports
1 x USB 3.0 9-Pin Header
StorageMicro-SD Card Slot (load system Image for non-eMMC CM4 version)
Camera1 x MIPI CSI Connector
Display1 x MIPI DSI Connector
1 x Micro HDMI Connector
FPCInterface for I2C and SPI
External FanPower connector for fan (For reference, please check this fan. The power connector fits)
Power5V/3A using USB Type-C Port
LAN7800 Temperature Range0°C to +70°C
Dimensions75x64x21mm
Weight43g
Hardware Overview
Dual Gigabit Ethernet NICs Carrier Board for Raspberry Pi Compute Module 4x1
Q&A
How can I install OpenWrt into this carrier board?
If you have CM4 with additional storage, you can refer to this wiki to check the installation.
My CM4 doesn't have any additional storage, how can I use the carrier board?
We provide a Micro-SD card slot for you to put the system-inside SD card into the carrier board and start the system with an SD card.
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
Dual Gigabit Ethernet NICs Carrier Board for Raspberry Pi Compute Module 4 - USB 3.0 connectors, Micro-HDMI interface, MIPI CSI/DSI, FPC connector, Micro-SD Card Slot, Compact size, OpenWrt supported
SKU 102110497
Dual Gigabit Ethernet NICs Carrier Board is a compact size board, where has been integrated Dual Gigabit Ethernet connectors and multiple peripherals, designed for miniature customizable network router applications, suitable for HTPC makers, Linux developers, software router enthusiasts, and the majority of regular Raspberry Pi users.
JPY¥7123.00
