おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • Ships with MeshCore Companion Bluetooth firmware pre-installed. The same hardware can also run Meshtastic firmware — see the wiki flashing guide before switching.
  • Set your LoRa region (e.g., US 902–928 MHz, EU 869.4–869.65 MHz) in the MeshCore app before first use; The region must match local regulations.
  • Charge with a standard 5 V USB power source (fast-charging chargers not recommended). The adapter is not included.
Pre-flashed MeshCore Firmware
  • Compatible with the MeshCore open-source mesh networking firmware, suitable for long-range and low-power communication needs. When you and your companions each carry a T1000-E paired with your phones, you can communicate and share locations directly through the app.
What is MeshCore? MeshCore User Guide
Robust Hardware for High-Precision GNSS Positioning
  • Built with low-power LoRa technology supporting the 863–928 MHz ISM band, Nordic nRF52840 processor, and MediaTek AG3335 GNSS module. It supports multi-constellation GNSS positioning, including GPS, GLONASS, Galileo, and BeiDou, for reliable outdoor location sharing without cellular coverage.
Encrypted Off-Grid Communication
  • MeshCore uses cryptographically signed node advertisements and encrypted private messaging to help prevent identity spoofing and protect direct communication over the mesh network.
Card-Sized, IP65-Rated Design
  • The same footprint as a credit card is just 6.5 mm thick and about 32 g, with an IP65 enclosure that stands up to dust and rain for everyday outdoor carry.
Versatile Design
  • The T1000-E features a 700 mAh rechargeable lithium battery with battery-level monitoring. It uses magnetic pogo-pin charging to maintain the sealed enclosure design and supports multiple carrying accessories, including Snap Hook, Adhesive Back Clip, and Nylon Lanyard.
仕様
General
Network protocolLoRa(Supports 863-928 MHz range), Bluetooth v5.1
TemperatureRange: -20 to 60℃;Accuracy: ± 1℃ (min ±0.5℃, max ±1℃)Resolution: 0.1℃
Light0 to 100% (0% is dark, 100% is brightest)
3-Axis AccelerometerBuilt-in motion sensor. Function availability depends on firmware support.
LED and Buzzer1*LED and 1* buzzer to indicate status
Button1* Button to operate
AntennaInternal (GNSS/LoRa/Wi-Fi/BLE)
Communication Distance2 to 5km (depending on antenna, installation, and environments)
IP RatingIP65
Dimensions85 * 55 * 6.5 mm
Device Weight32g
Operating Temperature-20℃ to +60℃
Operating Humidity5% - 95% (No condensation)
CertificationCE /FCC/RoHs/Telec
Battery
Battey CapacityRechargeable lithium battery, 700mAh
Battery Life MonitoringBattery level available through compatible MeshCore clients
Charge Cable(Adapter not included)USB magnetic charging cable, 1 meter
Power Input Voltage4.7 to 5.5V DC
Charging Temperature Limit0 to +45℃
ハードウェア概要
用途
Connect with nearby nodes, participate in public channels, and share geographic locations — in all areas without cellular coverage.
Recommended Use Cases:
  • Outdoor Adventure: Use this ready-to-use MeshCore device for off-grid communication with your hiking or camping group. The built-in GNSS module enables users to share location updates over compatible MeshCore networks. Location availability depends on satellite reception, device settings, and network conditions.
  • Festivals & Large Events: Stay connected with your group at races, festivals, and other large events when crowded venues make cellular service unreliable — no network infrastructure required.
  • Disaster Response & Emergency Comms: Rely on dependable communication and location sharing in disaster zones and emergency areas where network infrastructure is unavailable, supporting response and relief coordination.
ドキュメント
認証
HSCODE8526919090
USHSCODE8526910040
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Tracker T1000-Ex1
USB Cable (adapter not included)x1
  • Regional Availability
This product is not available for sale, shipment, or resale in Mainland China due to regional restrictions.
Unlike traditional GNSS trackers that depend on cellular networks, the SenseCAP T1000-E is a MeshCore-compatible GNSS tracker designed for off-grid communication and location sharing. Here are the key differences: ① No Monthly Subscription Fees – The T1000-E does not require a SIM card or recurring cellular service plan, helping reduce long-term costs. ② MeshCore-Compatible LoRa Mesh Networking – It uses LoRa mesh technology to relay messages and GNSS locations through nearby MeshCore repeater nodes, extending communication beyond direct point-to-point connections. ③ Long Battery Life – Powered by LoRa, a long-range and low-power communication technology, the T1000-E can operate for up to about 2 days on a single charge under typical use, making it ideal for extended outdoor use. ④ Reliable Off-Grid Communication – Stay connected in remote areas where mobile coverage is limited, as well as in crowded environments where cellular networks may become congested. It is ideal for hiking, camping, emergency preparedness, large festivals, races, and outdoor expeditions. ⑤ GNSS Tracking and Messaging in One Device – In addition to location sharing, the T1000-E supports MeshCore messaging, enabling both communication and coordination in the field. ⑥ Built for Outdoor Use – With its compact form factor and IP65-rated protection, the T1000-E is designed to withstand real-world outdoor environments. If you're looking for a MeshCore GNSS tracker, LoRa GNSS tracker, off-grid GNSS device, or a GNSS tracker without monthly fees, the SenseCAP T1000-E offers a practical alternative to conventional GNSS tracking solutions.
Battery life varies by device design and usage pattern, but MeshCore devices are generally built for low-power operation to support extended use in the field. The SenseCAP Card Tracker T1000-E for MeshCore is a compact, card-sized node weighing about 32 g and offers up to 2 days of battery life under typical usage (varies with GNSS fix interval, temperature, and LoRa settings), balancing portability and runtime.
Communication range depends on terrain, obstacles, antenna orientation, LoRa settings, and the availability of compatible MeshCore repeaters. Repeaters can extend coverage beyond direct device-to-device communication, but the achievable range varies by deployment.
MeshCore communication devices are commonly valued for the following features: Signed & Encrypted Communication - Node advertisements are digitally signed, allowing other nodes to verify their authenticity and helping protect against identity spoofing. - MeshCore supports encrypted direct messages and private group channels. Public channel messages should be considered public. Efficient Mesh Routing - Zero-hop or flooded adverts for node discovery; repeaters forward packets along learned routes rather than rebroadcasting everything – self-forming coverage with efficient airtime use. - Self-forming mesh that relays messages across multiple nodes Low Power Consumption - Optimized for long battery life - Designed for continuous use without frequent recharging Mobile & Web App Integration - Configuration and messaging via iOS and Android companion apps - Also accessible from a browser-based web app SenseCAP Card Tracker T1000-E Highlights - Card-sized and lightweight (~32 g) for everyday carry - Durable build with high-quality antenna design - IP65 dust-tight and water-resistant enclosure - Suitable for outdoor, industrial, and emergency scenarios
Yes. The SenseCAP Card Tracker T1000-E for MeshCore is designed for these environments. It features an IP65-rated enclosure, an optimized antenna design, helping maintain reliable communication even in remote or challenging terrain.
SKU 100094307
It is a compact MeshCore device designed for off-grid communication and location sharing.
About the size of a credit card, it can be easily carried or attached to gear for outdoor use. Powered by Semtech's LR1110 LoRa transceiver (863–928 MHz), Nordic's nRF52840 processor, and the MediaTek AG3335 GNSS module, it enables reliable long-range LoRa communication and location updates within MeshCore networks.
USD$39.90
product.detail.alsoAdd.title
