おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
MeshCore is a multi platform system for enabling secure text based communications utilising LoRa radio hardware. It can be used for Off-Grid Communication, Emergency Response & Disaster Recovery, Outdoor Activities, Tactical Security including law enforcement, private security and also loT sensor networks.
SenseCAP Solar Node P1-Pro for Meshcore comes with pre-flashed Meshcore Repeater firmware.
Note:
To replace the battery, please use a button-top 18650 battery. Please check this [compatible battery example] for reference.
仕様
Note:
Enjoy 5% off when you purchase any one MeshCore device – the SenseCAP Solar Node P1-Pro (SKU 100023690) or the Wio Tracker L1 Pro (SKU 100030144).
Get up to 8% off when you add both models to your cart.
No quantity limits – discount auto-applies at checkout.
  • Utilizes a 5W solar panel in combination with 4*18650 batteries with a capacity of 3350mAh each. This setup ensures continuous operation even in the absence of sunlight, effectively solving the problem of outdoor power supply.
  • The device comes pre-flashed with MeshCore firmware at the factory.
  • Features a built-in XIAO L76K GPS module, enabling high-precision real-time positioning. It supports real-time sharing of location information, providing reliable location assurance for outdoor activities.
  • It is suitable for long-term outdoor use.
  • The communication range between the two devices can reach 8-9KM in open areas. It can seamlessly integrate into the MeshCore ecosystem and be used as an outdoor node or repeater to easily expand the Mesh network, enhancing network coverage.
    • Accessory Options
      If you need an antenna with higher gain, we recommend these antennas:
      860-930MHz-3dBi-360mm
      900-930MHz-7dBi-920mm
      902-930MHz-8dBi-1300mm
      • Plug-and-play: Comes with a standard RF cable, which can be directly inserted into the pre-drilled hole (standard D-shaped hole) on the Solar Node bracket
      • Three-step installation: Align → Insert → Lock
        Main controller
        Xiao nRF52840 Plus (Nordic nRF52840, ARM® Cortex®-M4 32-bit processor with FPU, 64 MHz, 256KB RAM, 1MB Flash, 2MB onboard Flash)
        LoRa Module
        Wio-SX1262 (Semtch SX1262, TXOP=22dBm@862-930MHz)
        GPS Module
        L76K (Support GPS/GLONASS/Galileo)
        Antenna
        LoRa:
        Type: Rod-shaped rubber antenna
        Frequency range: 868-915MHZ
        Gain: 2dbi
        GNSS:
        GPS L1 C/A: 1575.42MHz
        GLONASS L1: 1602MHz
        BeiDou B1: 1561.098MHz
        Bluetooth 5.0
        Solar Panel
        5W
        Interface
        Grove *1: IIC/GPIO/UART
        USB-C debugging
        Button
        Power on/off
        Reset
        User-defined
        LED
        Charging status indicator lights *2
        Solar panel status indicator light *1
        Mesh heartbeat light *1
        User-defined *1
        Power supply
        Type-C: 5V 1A
        Solar power supply: 5V 1A
        Battery
        4 x 18650 lithium batteries (3350mAh each)
        ● Supporting Type-C and solar charging.
        ● Discharge environment:-40 ~ 60°C
        ● Charging environment: 0 ~ 50°C
        Certification
        FCC、CE
        Dimension
        191.2 x 201.2 x 42.1 mm
ハードウェア概要
  • Diagram
  • Overall effect diagram
  • Accessories diagram
①
2dbi, 868~915MHz rubber rod antenna
②
Universal joint bracket, angle adjustable.
③
Bracket connector, can support the antenna
④
RF Cable; RP-SMA Male to RF-SMA Female; 300mm
⑤
Hoop bracket
Diameter:
70-100mm
⑥
Hoop ring
  • Interactive items
⑦
Power switch
⑧
Reset
⑨
User-defined
⑩
Red light on: Charging
⑪
Green light on: Charged
⑫
Yellow light on: Device is exposed to light.
⑬
Blue light: Wait to be defined
⑭
White light: Mesh light
⑮
Type-C: 5V 1A
  • Dimension diagram
用途
  • Outdoor Adventure: Send real-time location and text messages in areas without network coverage.
  • Mesh Network Expansion: Serve as a Mesh relay node to expand the coverage of the existing MeshCore Support multi-hop transmission, where data can be relayed through multiple nodes, enhancing network reliability.
  • Educational Experiments: Learn about the development of MeshCore and LoRa decentralized networks.
認証
HSCODE8517629990
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
SenseCAP Solar Node P1-Pro (with GPS & battery)
x1
Mounting Brackets
● Universal Joint
● Connector
● Hoop Bracket
● Hoop Ring
x1
2dBi 868 - 915MHz Rubber Rod Antenna
x1
RRF Cable; RG316 coaxial cable; RP-SMA Male to RF-SMA Female; 300mm
x1
1/4-20 UNC Hex Head Machine Screw, 6 mm Long(Screw Pack)
x2
Screw, Phillips Pan Head Machine, M6 × 14 mm, P1.0(Screw Pack)
x4
Black Type-C Cable
x1
User Manual
x1
SenseCAP Solar Node P1-Pro for MeshCore
SKU 100023690
This device is pre-flashed with MeshCore repeater firmware. Powered by the Seeed XIAO nRF52840 Plus Module, Wio-SX1262 LoRa module, and L76K GPS modules, this solar-driven node leverages the nRF52 architecture for ultra-low power management—delivering long-range communication and precision positioning while maintaining full compatibility with the MeshCore ecosystem for decentralized, off-grid networking and mobile app integration.
USD$93.90
product.detail.alsoAdd.title
