おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
A MeshCore Device You'll Actually Carry
The SenseCAP MeshTracker X1 is designed for people who need reliable off-grid communication and location sharing beyond cellular networks—whether exploring the outdoors, attending large events, or preparing for emergencies. Its compact, genuinely portable form factor and rugged IP66 protection bring MeshCore connectivity to everyday carry and real-world field use.
Dual-Band GNSS Positioning
MeshTracker X1 combines dual-band L1 + L5 GNSS with a built-in barometer for outdoor positioning and pressure sensing. Dual-band GNSS can improve positioning in challenging signal conditions; actual accuracy depends on satellite visibility and the environment. Location sharing and sensor data availability depend on the MeshCore firmware and app version.
Reliable Long-Range Communication
MeshTracker X1 has achieved up to 8 km of communication range in open line-of-sight testing at 915 MHz. This is a reference test result, not a guaranteed range for every MeshCore setup. Actual range depends on terrain, obstructions, antenna orientation, radio settings, and interference. Configure frequency and transmit power for local regulations.
Next-Generation LoRa Hardware (LR2021)
The Semtech LR2021 transceiver provides the radio hardware for MeshCore LoRa communication. Receiver sensitivity depends on the selected bandwidth and spreading factor. Its FLRC capability is a separate radio mode: the chip-level maximum of 2.6 Mbps is not the MeshCore LoRa data rate. Voice, image, and high-speed data features require compatible firmware and client support and are not promised by the hardware specification alone.
Card-Sized Design, Easy to Carry
Slim and lightweight, the MeshTracker X1 is designed for everyday carry and outdoor adventures. Wear it on a lanyard, attach it to a backpack, secure it to a bike bag, or simply slip it into your pocket for effortless MeshCore connectivity wherever you go.
Vibration and Buzzer Hardware
MeshTracker X1 includes a vibration motor and buzzer for tactile and audible feedback. Available alerts and notification settings depend on the installed MeshCore firmware and client version.
IP66 Rugged Outdoor Protection
The IP66-rated enclosure provides protection against dust ingress and powerful water jets for outdoor use. IP66 does not cover immersion. Keep the USB-C port dry before charging.
USB-C Connectivity
Standard USB-C interface for charging, firmware updates, and debugging, designed for rugged outdoor use and everyday convenience.
The built-in 1100 mAh rechargeable battery supports portable off-grid use. Actual runtime varies with firmware, GNSS activity, Bluetooth connection, radio settings, and message traffic.
仕様
Main ControllerNordic nRF52840
LoRaSemtech LR2021Frequency Range: 863–928 MHz
MAX TX Power: 22 dBm
WirelessBluetooth (v5.0)
LED1 × RGB
Buzzer1 × buzzer to indicate status
Button1 × button to operate
Vibration1 × DRV2605L
SensorAir PressureRange: 300–1100 hPa
Accuracy: ±0.06 hPa
Resolution: 0.06 Pa
Temperature
(Read from barometer)
Range: −40–85°C
Resolution: 0.0006°C
* IMU + Magnetometer
BatteryBattery CapacityRechargeable high-voltage battery, 1100 mAh
Battery Life MonitoringPeriodic uplink battery level
Charging Protocol
Power InputDevice: 5 V, 0.55 A
Battery: 4.4 V, 0.22A
Fully-charged cut-off voltage4.37V
Charging Temperature Limit5 to +45℃
AntennaInternal (GNSS/863-928MHz LoRa/Bluetooth)
Communication DistanceUp to 8 km
IP Rating
Dimensions90 × 57 × 8 mm
Device Weight45 g
Operating Temperature−20 to 60℃
CertificationCE/FCC/RoHS/TELEC
IMU and magnetometer are not included in this model. Specifications for future X1 variants will be announced separately.
ハードウェア概要
Hardware Diagram
用途
From crowded festivals to remote mountain trails, MeshTracker X1 helps you stay connected, share locations, and coordinate with your group—even when cellular networks are unavailable or overloaded.
Recommended Use Cases:
  • Hiking & Outdoor Adventures
Stay Connected Beyond Cell Coverage
Whether hiking through forests, exploring mountain trails, or backpacking into remote areas, MeshTracker X1 lets your group share locations and communicate when mobile coverage disappears.
  • Cycling & Skiing
Track, Coordinate, and Ride Together
Share location updates and coordinate meetups while cycling or skiing. Update frequency and message delivery depend on GNSS reception, firmware settings, and available radio coverage.
  • Festivals, Events & Races
Keep in Touch with Your Group
Exchange messages and location updates during festivals, outdoor events, and races without relying on cellular service. Communication requires compatible MeshCore devices with matching radio settings and sufficient direct or repeater coverage.
  • Safety & Emergency Preparedness
Communication When It Matters Most
MeshTracker X1 can provide an additional way to exchange messages and location updates when cellular service is unavailable. Delivery depends on power and radio coverage; it is not a guaranteed emergency alert or rescue service.
ドキュメント
認証
HSCODE8517629990
USHSCODE8517620090
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
MeshTracker X1
x1
20 cm USB-C Cable
x1
Leather Keychain
x1
MeshTracker X1 can achieve communication distances of up to 8 km in open line-of-sight conditions during testing at 915 MHz. Actual range depends on factors such as terrain, antenna orientation, environmental interference, and network conditions. Mesh networking allows messages to travel further through connected nodes.
MeshTracker X1 and satellite communicators serve different purposes. MeshTracker X1 is designed for local off-grid communication through LoRa mesh networks, making it ideal for groups traveling together within mesh coverage. Unlike satellite devices, it does not require a subscription or satellite connection, but communication range depends on available mesh nodes.
MeshTracker X1 provides up to 5 days of battery life on a single charge, depending on usage patterns, GPS settings, communication frequency, and environmental conditions.
MeshTracker X1 is designed with next-generation LR2021 LoRa technology, providing higher data capability for future software expansion. Future features may include richer data transmission, such as voice and image capabilities, as the ecosystem develops. Please stay tuned!
Both MeshTracker X1 and SenseCAP T1000-E are compact MeshCore devices designed for off-grid communication. Choose MeshTracker X1 if you need higher-accuracy positioning, stronger communication performance, USB-C charging, longer battery life, and a more rugged design for demanding outdoor activities. Choose SenseCAP T1000-E if you prioritize an ultra-lightweight, compact tracker for everyday location sharing and casual outdoor use.
SenseCAP MeshTracker X1 for MeshCore
SKU 100019795
A card-sized MeshCore companion for off-grid messaging and location sharing. MeshTracker X1 combines dual-band L1 + L5 GNSS, a Semtech LR2021 LoRa transceiver covering 863–928 MHz, an IP66-rated enclosure, and a 1100 mAh rechargeable battery with USB-C charging. Pair it with a compatible MeshCore app over Bluetooth to exchange messages beyond cellular coverage.
USD$49.90
product.detail.alsoAdd.title
