おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
⚠️Buying Guide
This is a fully assembled version, ready to use out of the box. Items pre-selected are essential for smooth robotic arm operation. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a workbench. Please make sure to include one if you do not already have it. All other accessories are optional and can be purchased as needed.
  • Built for Physical AI — Affordable 6+1-DoF robotic arm for sim-to-real learning.
  • Completely Open — Hardware, software, CAD, SDK, BOM, and algorithms included.
  • Learn Faster — Comprehensive tutorials from assembly to deployment.
  • Always Improving — Free algorithm updates, demos, and learning resources.
  • Precision Motion — ±0.1 mm repeatability powered by RobStride Dynamics motors.
  • Robotics Ecosystem — Compatible with ROS, NVIDIA Isaac Sim, LeRobot, Pinocchio.
  • More Robotics for Less — Professional capabilities at an accessible price.
仕様
Degrees of Freedom6+1
Reach754.7mm<br>587.5mm(without gripper)
Payload2.5kg (Rated load)<br>5kg(Maximum load)
Repeatability0.1 mm
Weight6.7kg
ServosROBSTRIDE 06 x3<br>ROBSTRIDE 00 x4
Operating Temperature-20°~50°
PowerDC 48V 15A
ROS1✅
Moveit1✅
ROS2✅
Moveit2✅
Python✅
Lerobot✅
Isaac Sim✅
Pinocchio✅
Open Source✅
ハードウェア概要
用途
Learn & Build Robotics Easily
Lower the barrier to robotics with step-by-step tutorials. The reBot Arm B601-RS helps you go from assembly to intelligent robot control quickly and confidently.
Research & Laboratory Automation
High-precision robotics for liquid handling, sample transfer, and laboratory workflows. Built for repeatability, delicacy, and rapid experimentation.
Teleoperation & Physical AI
Power real-time control, data collection, and sim-to-real learning with leading robotics frameworks including LeRobot and Isaac Sim. A dexterous “hand” for embodied AI.
Industrial Automation & Logistics
±0.1 mm precision, up to 5 kg payload. The reBot Arm B601-RS enables precision assembly, inspection, sorting, and material handling in manufacturing and warehouse environments. Compact and easy to integrate into existing production lines and workcells.
Your Physical AI Project Deserves the Spotlight!
Seeed Studio's monthly "Physical AI Project of the Month" is now open for submissions—whether you're building with the reBot Arm (B601-DM/RS) or the SO-ARM (100/101), this is your chance to showcase your work to the global robotics community and get featured by Seeed Studio!
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
部品リスト
Assembled Robotic Arm (with gripper)1
RobStride USB-CAN Driver Board1
CANABLE1
XT30 2+2 Power Separation Board1
Hex key wrench set1
Mouse pad1
Wire kits1
Power Adapter for reBot Arm B601-RS1
reComputer J3011 - Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB1
reBot Arm B601-RS Assembled Kit with Jetson Orin
SKU E26062403
Combining NVIDIA Jetson Orin AI computing, fully open hardware and software, ±0.1 mm repeatability, and a 2.5 kg rated payload, the reBot Arm B601-RS delivers everything needed to build, train, and deploy next-generation Physical AI applications.
Robot Arm
Assembly Type
AI Computing Platform
USD$2627.00
reBot Arm B601-RS Assembled with Gripper (without power supply)x1$1799.00
Power Adapter Kit for reBot Arm B601-RSx1$79.00
reComputer J3011 - Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB (Support Super Mode)x1$749.00
product.detail.alsoAdd.title
