製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note
  • For optimal performance with reComputer, we recommend using 128GB / 256GB / 512GB / 1TB SSDs from Seeed. Since some SSDs on the market may only be compatible with specific JetPack versions which may cause the device to fail to function properly, and this issue is also present with official NVIDIA dev kits.
  • If you are looking for the version with power adapter, please check out reComputer J2021 Edge device
仕様
Jetson Xavier NX System on Module
AI Performance
reComputer J2022 - Jetson Xavier NX 16GB, 21 TOPS
reComputer J2021 - Jetson Xavier NX 8GB, 21 TOPS
GPU
384-core NVIDIA Volta™ architecture GPU with 48 Tensor Cores
CPU
6-core NVIDIA Carmel Arm®v8.2 64-bit CPU 6MB L2 + 4MB L3
Memory
16GB 128-bit LPDDR4x 59.7GB/s
8GB 128-bit LPDDR4x 59.7GB/s
Storage
16 GB eMMC 5.1
Video Encoder
2x 4K60 (H.265) | 4x 4K30 (H.265) | 10x 1080p60 (H.265) | 22x 1080p30 (H.265)
Video Decoder
2x 8K30 (H.265) | 6x 4K60 (H.265) | 12x 4K30 (H.265) | 22x 1080p60 (H.265) | 44x 1080p30 (H.265)
Carrier Board
Storage
1x M.2 Key M PCIe
Networking
Ethernet
1x RJ-45 Gigabit Ethernet (10/100/1000M)
M.2 KEY E
1x M.2 Key E
I/O
USB
4x USB 3.1 Type-A, 1x USBType-C (Device Mode)
Camera
2x CSI (2-lane 15pin)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (5V PWM)
CAN
1x CAN
Multifunctional Port
1x 40-Pin Expansion header
1x 12-Pin Control and UART header
RTC
1x RTC 2-pin, RTC socket
Power
9-16V DC
Mechanical
Dimensions (W x D x H)
130mm x 120mm x 58.5mm (with case)
Installation
Desk, wall-mounting
Operating Temperature
0℃~60℃
Note
Using GPIO libraries that cause floating voltages between 1.2V and 2V may lead to GPIO issues on the carrier board, as the normal voltage should be 3V
ハードウェア概要
  • Desktop, Wall Mount, Expandable, or Fit in Anywhere
用途
Application Fields:
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
Build Multi-streams AI Video Analytics
For building video analytics, Jetson Xavier NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) Check out our video analytics main page to find more vision AI developing tools and practical use case deployed in the field!
認証
HSCODE8471419000
USHSCODE8517180050
UPC
EUHSCODE8471800000
COOCHINA
reComputer J2021 (w/o power adapter) - Edge AI Computer with NVIDIA® Jetson™ Xavier NX 8GB
SKU 110061482
Powerful and compact edge AI device with NVIDIA® Jetson Xavier NX SoM, pre-built Jetpack 4.6.1, 4x USB 3.1, HDMI, DP, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
JPY¥87209.00
