Note
Jetson Xavier NX System on Module | ||
AI Performance | reComputer J2022 - Jetson Xavier NX 16GB, 21 TOPS | |
GPU | 384-core NVlDlA Voltaᵀᴹ architecture GPU with 48 Tensor Cores | |
CPU | 6-core NVIDIA Carmel Arm®v8.2 64-bit CPU 6MB L2 + 4MB L3 | |
Memory | 16GB 128-bit LPDDR4x 59.7GB/s | 8GB 128-bit LPDDR4x 59.7GB/s |
Video Encoder | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 10x 1080p60 (H.265) | 22x 1080p30 (H.265) | |
Video Decoder | 2x 8K30 (H.265) | 6x 4K60 (H.265) | 12x 4K30 (H.265) | 22x 1080p60 (H.265) | 44x 1080p30 (H.265) | |
Carrier Board | ||
Storage | 1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included) | |
Networking | Ethernet | 1x RJ-45 Gigabit Ethernet (10/100/1000M) |
M.2 KEY E | 1x M.2 Key E | |
I/O | USB | 4x USB 3.1 Type-A, 1x USBType-C (Device Mode) |
Camera | 2x CSI (2-lane 15pin) | |
Display | 1x HDMI 2.1 | |
Fan | 1x 4 pin Fan Connector (5V PWM) | |
CAN | 1x CAN | |
Multifunctional Port | 1x 40-Pin Expansion header 1x 12-Pin Control and UART header | |
RTC | 1x RTC 2-pin, RTC socket | |
Power | 9-16V DC | |
Mechanical | Dimensions (W x D x H) | 130mm x 120mm x 58.5mm (with case) |
Installation | Desk, wall-mounting | |
Operating Temperature | 0℃~60℃ | |
Note
Using GPIO libraries that cause floating voltages between 1.2V and 2V may lead to GPIO issues on the carrier board, as the normal voltage should be 3V
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
For building video analytics, Jetson Xavier NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) Check out our video analytics main page to find more vision AI developing tools and practical use case deployed in the field!
reComputer J2022 (System Installed) | x1 |
Powerful and compact edge AI device with NVIDIA® Jetson Xavier NX SoM, pre-built Jetpack 4.6.1, 128GB SSD, 4x USB 3.1, HDMI, DP, GbE, carrier board also includes M.2 key E for WIFI, M.2 Key M for SSD, RTC, CAN, 40-pin and more.
