おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
reComputer Mini J501 carrier board is compatible with Jetson AGX Orin module, featuring 2 Ethernet(1x 10GbE included), USB, RS-485, I2S and 8 GMSL extension, with almost same size layout of NVIDIA Jetson AGX Orin dev kit, perfect for autonomous robot/humanoid robot development
  • Powerful embodied AI Platform Compatible with the Jetson AGX Orin module, offering up to 275 TOPS. Perfect platform for embodied AI development.
  • Ultra Compact Size 110mm x 110mm footprint, suitable for robot prototyping and development, especially robots that has tight footprint such as humanoids
  • Wide Voltage Input Range Can be used in 48V battery power system (max 54V input)
  • Rich IO capabilities Includes most common IOs used in robotics prototyping, such as USB, 10G Ethernet, CAN, RS-485 and I2S
  • Vision AI Support Features 4x 4-lane CSI output, and can be connected up to 8x GMSL2 cameras, making it ideal for vision AI applications such as BEV, Occupancy Grid, SLAM etc
仕様
Product
reComputer Mini J501 Carrier Board with GMSL Extension
Storage
1x M.2 Key M slot
Networking
1x M.2 Key E slot for WiFi/Bluetooth module
I/O
USB
2x USB 3.2 Type-A (10Gbps);
1x USB 3.0 Type-C (Recovery);
1x USB 2.0 Type-C (Debug);
RJ45
1x 1G Ethernet
1x 10G Ethernet
GMSL
8x GMSL2 (MAX96712 as deserializer, Rosenberger Connector)
CAN
2x CAN (CAN-FD supported, Isolated)
RS485
1x RS-485
I2S
1x I2S
GPIO
4xGPI  4xGPO  (GPO can be configured as UART)
Display
1x HDMI 2.1
Fan
1x 4 pin Fan Connector (12V PWM)
Button
1x Reset Button; 1x Recovery Button
RTC
1x RTC 2-pin
Power
1 x XT30 Connector (19-48V DC)
Mechanical
Dimensions (W x D x H)
110mm x 110mm x 38mm
Weight
90g
Installation
Desk, wall-mounting
Operating Temperature
-10℃~60℃ (with thermal grease)
-10℃~55℃ (with thermal pad)
Warranty
2 Year
Compatible GMSL Cameras supported in Jetpack
Manufactuer
Model
Resolution
Sensing
SG3S-ISX031C-GMSL2F
1920H*1536V
SG2-AR0233C-5200-G2A
1920H*1080V
SG2-IMX390C-5200-G2A
1920H*1080V
SG8S-AR0820C-5300-G2A
3840H*2160V
Orbbec
Orbbec Gemini 335LG
3D
ハードウェア概要
用途
  • Humanoid Robotics
  • AI Robot Development
With AGX Orin module, this most powerful embedded AI system lets you create advanced robotics and edge AI applications for manufacturing, logistics, and healthcare. It’s the most powerful embedded system, pushing the limits of AI robotics. The Isaac robotics platform offers NVIDIA-accelerated systems, libraries, and generative AI models to enhance AI perception, manipulation, and simulation in robotics.
Learn about Issac platform
Isaac - AI Robot Development Platform | NVIDIA Developer
  • Multi-Sensor Fusion for Autonomous Mapping & Navigation
reComputer Mini J501 supports sensor-rich autonomy by integrating data from LiDAR (via Ethernet/CAN), 3D cameras (via USB/CSI), GPS, and IMU (via UART). Using AI models and algorithms like ORB-SLAM,A-LOAM, or Nav2, it performs sensor fusion, real-time localization, path planning, and obstacle avoidance. The low-latency processing on the AGX Orin SoC allows autonomous systems to adapt to changing terrain or obstacles on the fly. Its wide voltage input and compact form factor make it suitable for mobile deployment, enabling robust, edge-level autonomy without external compute.
Learn more about sensor options compatible with reComputer Mini J501 to get started.
  • Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
  • Deploy Depth Anything v3
reComputer Mini J501 enables real-time execution of the Depth Anything V3. By processing frames captured from a monocular camera, the system instantaneously generates high-precision depth maps and reconstructs 3D point cloud spaces. This empowers small-scale mobile robots with exceptional spatial perception, obstacle recognition, and real-time 3D modeling capabilities, making it ideal for low-power, high-performance robotic applications such as outdoor inspection, autonomous delivery, and environmental mapping.
  • Fruit Sorting with Mini J501 and StarAI Follower Arm Viola
Mini J501 (Jetson AGX Orin) and StarAI Follower Arm Viola utilizes the LeRobot framework to execute fruit sorting tasks.  The project showcases an end-to-end workflow from data collection to deployment, enabling the robot to intelligently grasp and organize fruits.
  • Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8; and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
Seeed Carrier Board (reComputer Mini J501)
x1
Power Board
x1
GMSL Extension Board (GMSL x8)
x1
XT30 to DC power cable
x1
USB Type-C to Type-A cable
x1
GH-1.25 4-pin 100mm JST Cable
x3
GH-1.25 6-pin 100mm JST Cable
x3
M3*16 Stud (For GMSL Extension)
x2
M2.5*4 Screw
x1
M2*6 Screw
x3
M2.5*25 Stud
x4
M2.5*8 Screw
x4
reComputer Mini J501 Carrier Board for Jetson AGX Orin™ with GMSL Extension
SKU 100020039
reComputer Mini J501 carrier board is a ultra-compact carrier board for NVIDIA Jetson AGX Orin™ modules, both 32GB and 64GB. It features rich IOs, including CAN, USB, Ethernet,RS-485, I2S and GMSL extension, making it perfect candidate for humanoid controller and rapid prototyping. For bundle options with AGX Orin™ modules, please see here.
USD$359.00
product.detail.alsoAdd.title
