製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Industry-standard Deserializer Selection Uses MAX96712 as deserializer
  • 6Gbps Data Rate Support Supports up to 6Gbps data rate per channel
  • Ready-to Use GMSL Camera models Supports multiple GMSL cameras in Jetpack (See table below for models)
仕様
Product
reComputer Robotics GMSL Board
Deserializer
MAX96712
Operating Temperature
-20℃~60℃
Mechanical Dimension
86mm x 31mm x 18mm
Cameras Supported in Jetpack
Manufactuer
Model
Resolution
Sensing
SG3S-ISX031C-GMSL2F
1920H*1536V
SG2-AR0233C-5200-G2A
1920H*1080V
SG2-IMX390C-5200-G2A
1920H*1080V
SG8S-AR0820C-5300-G2A
3840H*2160V
Orbbec
Orbbec Gemini 335LG
3D
ハードウェア概要
用途
  • Robotics (Object detection and 3D reconstruction)
  • BEV Detection
  • High-Performance Vision for Robotics
Combining a GMSL 2 camera with a reComputer Robotics enables advanced vision-based robotics. Sensing 3MP GMSL 2 camera supports real-time object detection, panoramic environment awareness, and multi-camera 3D reconstruction . The high-bandwidth, low-latency GMSL 2 link supports long cable runs and multi-camera setups, while the Jetson Orin NX delivers real-time AI processing for perception, mapping, and control.
  • 3D Vision and GMSL 2 Connectivity for Robotics
The reComputer Robotics GMSL Extension supports the Orbbec Gemini 335LG Stereo Vision 3D Camera, providing accurate real-time 3D perception for advanced robotics. With the MAX96712 deserializer and mini-FAKRA connector, it ensures secure, low-latency, and reliable data transmission, ideal for AMRs, robotic arms, and collaborative robots. Precise depth sensing enables smarter navigation, robust object recognition, and reliable obstacle avoidance across mobile robots, delivery systems, and shelf-stocking applications.
ドキュメント
認証
HSCODE8473309000
USHSCODE8473309100
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer GMSL Board
x1
M3 Stud
x2
M3 Screw
x2
SKU 100071398
reComputer Robotics GMSL board is a GMSL extension board designed specifically for reComputer Robotics series of Jetson™ Orin™ NX and Orin™ Nano . Both data and power are sent through coaxial cable. It uses MAX96712 as deserializer, and can be compatible with GMSL cameras that use MAX96717/MAX9295A as serializer. This GMSL board currently has native support for multiple Sensing cameras and Orbbec Gemini 335LG, and can be connected up to 4 cameras simultaneously.
JPY¥7756.00
