おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • Due to the characteristics of full-color ePaper, a full-screen refresh takes approximately 25–30 seconds and may involve visible color flashing before the final image stabilizes.
  • SenseCraft HMI has been renamed to SenseCraft Seeedash. Existing content remains available. Seeedash is currently in beta, with usage limits on AI and UI generation.
  • The reTerminal E Series comes with SenseCraft Seeedash firmware by default. Using TRMNL Dashboard firmware requires a separate TRMNL BYOD license.
  • If you need a larger ePaper panel for a digital photo frame, a 13.3" full-color version is also available.
  1. Beautiful, Ready-to-Use E Ink® Spectra™6 Color ePaper Display
The reTerminal E1002 comes fully assembled as an HMI (Human Machine Interface) in a sleek, durable enclosure, featuring an integrated 800×480 E Ink® Spectra™6 full-color ePaper display. Powered by Espressif’s ESP32-S3, it delivers vivid visuals and crisp text straight out of the box—no extra setup required.
  1. Ultra-Low Power with 3-Month Battery Life
Equipped with a built-in 2000mAh battery and engineered for maximum power efficiency, the reTerminal E1002 runs for up to 3 months on a single charge in deep sleep mode (6-hour refresh interval). Place it anywhere—on your desk, mounted on a wall, or in any space—without worrying about frequent recharging.
  1. No-Code UI Design & Deployment with SenseCraft Seeedash
Design and deploy personalized dashboards effortlessly with SenseCraft Seeedash, our new AI-powered no-code platform. Create your UI through simple drag-and-drop elements, choose from our rich templates, or let AI help you. Connect real-time data from onboard sensors or web APIs, then deploy your finished dashboard to reTerminal E1001/E1002 display with just a few clicks. From design to data configuration to deployment, everything happens seamlessly on one single platform.
  1. Works with Popular Software Platforms
Enjoy seamless compatibility with multiple software ecosystems. Create no-code TRMNL Dashboards with 300+ plugins for everyday and work data, connect instantly to Home Assistant via ESPHome firmware, or developing your customized applications using Arduino, PlatformIO or ESP32-IDF environment. You can also access all supported firmware and tools for the reTerminal E Series from one centralized Firmware Hub.
  1. Flexible Hardware & Software Customization
Leveraging Seeed Studio’s extensive OEM/ODM expertise, the reTerminal E10E1001/E1002 can be customized to fit your exact needs. Whether you require specific sensors, modified I/O configurations, or tailored UI designs, it’s built to adapt—ideal for industrial, educational, or personal use.
ESPHome Ready-Made Project: Zero-Code Setup!
Seeed Studio is proud to have joined the ESPHome Ready-Made Project. No YAML or coding required—flash your firmware directly via web browser for instant integration.
Featured Devices:
Experience seamless setup now at the ESPHome Ready-Made Projects website!
Explore landing page to discover more plug-and-play, Home Assistant–compatible devices designed for faster deployment and simplified integration.
仕様
Product Name
reTerminal E1001
reTerminal E1002
Processor
ESP32-S3 with 8MB PSRAM
Storage
32MB Flash, support Micro SD card
Display
7.5" Monochrome
7.3" Full Color
Resolution
800x480 Pixels
Micro SD Card
Maximum support 32GB SD card, FAT32 format
Wireless Connectivity
2.4GHz 802.11 b/g/n Wi-Fi, Bluetooth 5.0
Sensor
Temperature, humidity sensors
Microphone
Reserved for voice interaction application
Buzzer
Buzzer for sound alert
Battery
2000mAh
Power Input
USB-C 5V/1A
Software
Default firmware support SenseCraft Seeedash(SenseCraft Seeedash)
Support ESPHome firmware for Home Assistant
Support Arduino/PlatformIO/ESP-IDF development platform
Working Temperature
0-40°C
Dimensions
176mm*120mm*53mm(With Stand)/17mm(Without Stand)
ePaper Device Comparison
ePaper Displays in Comparison
reTerminal E1001
reTerminal E1002
XIAO 7.5'' ePaper Panel
TRMNL 7.5'' (OG) DIY Kit
Display
Size
7.5''
7.3''
7.5''
7.5''
Color
Monochrome
Full-color
Monochrome
Monochrome
Resolution
800×480
800×480
800×480
800×480
Partial Refresh
Refresh Rate
2-5s
12-15s
2-5s
2-5s
MCU
ESP32-S3
ESP32-S3
ESP32-C3
ESP32-S3
Enclosure
Metal
Metal
3D Printed PLA
SD Card Support
Battery
Capacity
2000mAh
2000mAh
2000mAh
2000mAh
Monitoring
Expansion Interfaces
UART & I2C
UART & I2C
Compatible Software
SenseCraft Seeedash
Home Assistant/ESPHome
TRMNL
Arduino
EEZ Studio
SenseCraft Seeedash
TRMNL
Arduino
Sqaureline Vision
EEZ Studio
TRMNL
Arduino
TRMNL
SenseCraft Seeedash
Home Assistant
Arduino
Certifications
FCC/CE/MIC Radio/ROHS
MSRP
$69-$76.99
$99-$109.99
$65.55-$72.19
$42.66-$46.54
ハードウェア概要
用途
  • Desktop Personal Assistants:Show colorful pictures or photos, track calendars, notifications, weather, or news as a stylish, energy-efficient alternative to tablets.
  • Home Automation Dashboards:Display real-time smart home data like temperature, humidity, and air quality via Home Assistant.
  • Smart Office Displays:Show meeting room availability, office schedules, or directional guidance in low-power, always-on ePaper displays.
  • Retail & Public Information Displays:Low-power ePaper signs for menus, schedules, or occupancy indicators with long battery life.
  • Education & Rapid Prototyping:An ideal platform for developers and students to learn IoT, embedded systems, and no-code UI design, while quickly prototyping and testing sensors, modules, or custom dashboards.
認証
HSCODE8543709990
USHSCODE8524119000
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reTerminal E1002 ePaper Display
X1
USB Type-C cable
X1
Display stand with screw
X1
Screw driver
X1
reTerminal E1002 Full-color ePaper Display
SKU 100017057
reTerminal E1002 is a 7.3 inch open-source full color ePaper display with up to 3-month battery life. Powered by ESP32-S3, it natively supports our SenseCraft Seeedash no-code UI platform for effortless dashboard creation, while supporting Home Assistant, TRMNL E-ink dashboard, Arduino and ESP-IDF for further development. With the E Ink® Spectra™ 6 full-color ePaper Display, it's perfect for digital frame, colorful dashboard visulization.
JPY¥15527.00
¥17252.00
Save ¥1725.00(10%)
product.detail.alsoAdd.title
