Product Details
Wiki & Learn
Reviews
Download PDF
Feature
Note:
  • Smaller display options are also available within the reTerminal ePaper series, including 7.5'' monochrome and 7.3'' full-color versions.
  • Compatible with ESPHome and Home Assistant, making it ideal for building a touch-enabled smart home dashboard.
  • SenseCraft HMI has officially been renamed to SenseCraft Seeedash. All your existing content remain available as before.
  • 3-Second Full Refresh for Faster ePaper Responsive Dashboards
With an integrated T-CON timing controller, the reTerminal E1003 enables full-display refresh in just 3 seconds, significantly improving responsiveness compared to typical ePaper update performance. It’s ideal for smart home dashboards, control panels, and dynamic status displays that require faster visual feedback with minimal delay.
  • Design Dashboards Faster with SenseCraft Seeedash
The reTerminal E1003 works with SenseCraft Seeedash, a no-code UI design platform with ready-to-use templates for quickly creating and deploying dashboards. With built-in touch support in the SenseCraft Seeedash firmware, you can wake the display with a simple tap and navigate between pages naturally, making multi-page dashboards easier and more intuitive to use.
  • Expand Possibilities with Touch Interaction
With built-in touch support, the reTerminal E1003 lets you interact directly with on-screen content—make selections, confirm tasks, adjust settings, or control connected functions. This transforms the display from a passive information screen into an intuitive interactive interface for smart home control, status dashboards, checklists, kiosks, and other customized applications, making everyday interactions faster and more natural.
  • Crisp Visuals with 16-Level Grayscale and High-Resolution ePaper Display
The 10.3-inch ePaper display with 1404 × 1872 resolution and 16-level grayscale support delivers richer visual detail compared to typical monochrome ePaper panels. Whether showing dashboards, UI layouts, or data visualizations, the reTerminal E1003 provides clearer structure, improved readability, and more flexibility for information-rich interfaces.
  • 6-Month Battery Life for Truly Cable-Free Placement
Equipped with a built-in 3000mAh battery, the reTerminal E1003 runs up to 6 months on a single charge in the low power mode under a once-per-day refresh scenario. With no wiring required, it can be easily deployed on walls, desks, or anywhere dashboards and control panels are needed.
  • Flexible Hardware & Software Customization
Leveraging Seeed Studio’s extensive OEM/ODM expertise, the reTerminal E1003 can be customized to fit your exact needs. Whether you require specific sensors, modified I/O configurations, or tailored UI designs, it’s built to adapt—ideal for industrial, educational, or personal use.
Product Name
reTerminal E1003
Processor
ESP32-S3 with 8MB PSRAM
Storage
32MB Flash, support Micro SD card
Display
10.3" Monochrome/ 16-level Grayscale
Resolution
1404x1872 Pixels
Micro SD Card
Maximum support 32GB SD card, FAT32 format
Wireless Connectivity
2.4GHz 802.11 b/g/n Wi-Fi, Bluetooth 5.0
Sensor
Temperature, humidity sensors
Microphone
Reserved for voice interaction application
Buzzer
Buzzer for sound alert
Battery
3000mAh
Power Input
USB-C 5V/1A
Software
Default firmware support SenseCraft Seeedash(SenseCraft Seeedash)
Support Arduino/PlatformIO development platform
Working Temperature
0-40°C
Dimensions
224mm*187mm*18.6mm
ePaper Device Comparison
ePaper Devices in Comparison
reTerminal
E1001
reTerminal
E1002
reTerminal
E1003
reTerminal
E1004
Display
Size
7.5''
7.3''
10.3''
13.3''
Color
Monochrome
Full-color
Monochrome
Full-color
Grayscale
4
16
Resolution
800×480
800×480
1404×1872
1200×1600
Partial Refresh
Refresh Rate
2-5s
15-20s
2-3s
Around 20s
MCU
ESP32-S3
ESP32-S3
ESP32-S3
ESP32-S3
Enclosure
Metal
Metal
Metal
Metal
SD Card Support
Battery
Capacity
2000mAh
2000mAh
3000mAh
5000mAh
Monitoring
Touch
Expansion Interfaces
UART & I2C
UART & I2C
I2C & GPIO
I2C & GPIO
Compatible Software
SenseCraft Seeedash
Home Assistant
Arduino
TRMNL
EEZ Studio
SquareLine Vision
SenseCraft Seeedash
Home Assistant
Arduino
TRMNL
EEZ Studio
SquareLine Vision
SenseCraft Seeedash
Arduino
ESPHOME
TRMNL
SenseCraft Seeedash
Arduino
Certifications
FCC/CE/TELEC/
PSE/ROHS/UKCA
FCC/CE/TELEC/
PSE/ROHS/UKCA
FCC/CE
FCC/CE
MSRP
$69.00
$99.00
$159.90
$279.90
Hardware Overview
  • Screen Refresh Button
  • Page Up and Down Button
  • Wi-Fi Antenna Area
  • MicroSD Card/TF Card port
  • Power Switch
  • Red Power LED
  • Green Status LED
  • USB-C Data and Charge Port
  • Expansion Port
  • Stand Mounting Screw Hole
  • Stand
Application
  • Home Automation Dashboards: Display real-time smart home data like temperature, humidity, and air quality via Home Assistant.
  • Low-power Monochrome electronic photo frame: With SenseCraft HMI or the App, you can easily upload a series of photos from your album remotely online. Combined with a large, high-resolution monochrome e-ink screen, it achieves ultra-low power image display, no longer have to worry about battery life.
  • Smart Office Displays: Show meeting room availability, office schedules, or directional guidance in low-power, always-on ePaper displays.
  • Retail & Public Information Displays: Low-power ePaper signs for menus, schedules, or occupancy indicators with long battery life.
Certification
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
reTerminal E1003 ePaper Display
X1
USB Type-C Cable
X1
3D Printed Stand
X1
Screw Driver
X1
Screw
X1
reTerminal E1003 10.3'' Monochrome ePaper Display
SKU 100090602
reTerminal E1003 is a 10.3 inch touch-supported, open-source monochrome ePaper display featuring 16 levels of grayscale and a high-resolution of 1404×1872 pixels, with up to 6-month battery life. Powered by ESP32-S3, it natively supports our SenseCraft Seeedash no-code UI platform for effortless dashboard creation. Whether for smart home dashboard visualization and control, office information displays, or educational projects, this ready-to-use touch-enabled device delivers stunning visuals and flexible customization to meet all your needs.
JPY¥25308.00
