おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note:
  • The reTerminal E Series Display supports SenseCraft HMI by default firmware.
  • SenseCraft HMI has officially been renamed to SenseCraft Seeedash. All your existing content remain available as before.
  • The SenseCraft Seeedash platform is now in the beta trial stage, and the functions will be continuously improved. At present, there is a limit to the number of AI generation and UI generation.
  • Compared with printed photos , reTerminal E1004 delivers a paper-like viewing experience while allowing photo updates in about 20 seconds.
  • If you need a smaller ePaper panel, 7.5" monochrome and 7.3" full-color versions are also available.
  • Compatible with ESPHome and Home Assistant, making it ideal for building a touch-enabled smart home dashboard.
  • High-resolution,Beautiful and Ready-to-Use E Ink® Spectra™6 Color ePaper Display
The reTerminal E1004 is presented as a fully assembled human-machine interface (HMI) with an aluminum frame, featuring a 1200×1600 E Ink® Spectra™6 full-color e-paper display. Powered by Espressif’s ESP32-S3, it delivers vivid visuals and crisp text straight out of the box—no extra setup required.
  • No-Code UI Design & Deployment with SenseCraft Seeedash
Design and deploy personalized dashboards effortlessly with SenseCraft Seeedash(SenseCraft Seeedash), our new AI-powered no-code platform. Create your UI through simple drag-and-drop elements, choose from our rich template library, or let AI help you. Connect real-time data from onboard sensors or web APIs, then deploy your finished dashboard to reTerminal E1004 display with just a few clicks. From design to data configuration to deployment, everything happens seamlessly on one single platform.
  • Image Slideshows with Live Data Sync&Battery Lasts for Months
Equipped with a built-in 5000mAh battery and engineered for maximum power efficiency, the reTerminal E1004 runs for up to 6 months on a single charge in Low-Power Mode(6-hour refresh interval). Place it anywhere—on your desk, mounted on a wall, or in any space—without worrying about frequent recharging.Supports automatic image carousel and real-time data updates, creating a "breathing" smart photo frame!
  • Adapting to decoration and display needs in different scenarios
Wire-free for more freedom; supports wall-mount/desktop placement, one-click switch between portrait and landscape modes, adapting to decoration and display needs in different scenarios
  • Display Your Content Locally with More Privacy
With MicroSD card support, the reTerminal E1004 lets you bring your favorite images directly from your computer to the display. No account or cloud upload is required for this local workflow—simply save the files to the card and insert it into the device. Your content remains on your own storage, making it suitable for private photo displays, family information boards, and personalized visual spaces.
仕様
Product Name
reTerminal E1004
Processor
ESP32-S3 with 8MB PSRAM
Storage
32MB Flash (16GB SD Card included)
Display
13.3" Full Color
Resolution
1200x1600 Pixels
Micro SD Card
FAT32 format(Maximum support 32GB SD card)
Wireless Connectivity
2.4GHz 802.11 b/g/n Wi-Fi, Bluetooth 5.0
Touch Buttons
Image refresh and switching
Sensor
Temperature, humidity sensors
Buzzer
Buzzer for sound alert
Battery
5000mAh
Power Input
USB-C 5V/1A
Software
Default firmware support SenseCraft Seeedash(SenseCraft Seeedash)
Working Temperature
0-40°C
Dimensions
376mm*311mm*40mm
用途
Low-power color electronic photo frame:
With SenseCraft HMI or the App, you can easily upload a series of photos from your album remotely online. Combined with a large, high-resolution color e-ink screen, it achieves ultra-low power image display, no longer have to worry about battery life.
Family Information Board:
Displays colorful images or photos, keeps track of calendars, notifications, weather, or news, serving as a stylish and energy-efficient information display board.
Smart Office Displays
Show meeting room availability, office schedules, or directional guidance in low-power, always-on ePaper displays.
Retail & Public Information Displays
Low-power ePaper signs for menus, schedules, or occupancy indicators with long battery life.
認証
HSCODE8543709990
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
reTerminal E1004 ePaper Display
X1
USB Type-C cable
X1
Display stand with screw
X1
Screw driver
X1
Frame hooks
X2
reTerminal E1004 13.3" Full-color ePaper Display
SKU 100064156
reTerminal E1004 is a 13.3 inch open-source full color ePaper display with up to 6-month battery life. Powered by ESP32-S3, it natively supports our SenseCraft Seeedash no-code UI platform for effortless dashboard creation, easily upload images to the device. With the E Ink® Spectra™ 6 full-color ePaper Display, it's perfect for digital frame, colorful dynamic dashboard.
USD$279.90
product.detail.alsoAdd.title
