An important tool that every climber and hiker on an expedition needs is a form of navigation. Nevertheless, handheld GPS systems can be relatively expensive therefore many resorts to using traditional maps.
This GPS Navigator Kit can exactly to judge their position via latitude, longitude, and altitude. It can show you the number of satellites connecting to the Wio Terminal as well, and also other useful information such as your movement speed for your to maintain your cadence. It also displays a visual map to show you the satellite direction. With a little bit of tinkering, you can customise the interface for it to display only the information you need too!
This GPS Navigator Kit provides you with everything you need to create your own DIY GPS navigator, with a Wio Terminal paired up with a battery chassis, and a Grove GPS Sensor. Thanks to a guide by manpukukoji on Hatena Blog, you can easily copy the preinstalled code to the easy-to-use Arduino IDE interface and get your Wio Terminal to display your position’s latitude, longitude and altitude via the information from the Grove GPS Sensor.
Create your own DIY Arduino GPS with this kit to obtain the positional and satellite information of your location
Read the latitude, longitude, altitude, and several other information displayed on the Wio Terminal Screen
No WIFI or Bluetooth connection required
Positioning error within 10 meters
Multi-mode satellite positioning & navigation and support for more than 6 satellites at the same time
Built-in 650mAh Rechargeable Lithium Polymer Battery
Easy-to-use modular Grove ecosystem accelerates hardware prototyping process
GPS for Hiking and Mountaineering Navigation
Wio terminal GPS - Hackster.io - Credits to manpukukoji on Hatena Blog
