製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
【Ends on Dec 31 , 2026(GMT+8) |Applicable to all warehouses】
Discount will be automatically applied after selecting the shipping method.If you find that the discount is not applied, please clear the cache and try again.
  • Next-Gen Performance, 4× Faster: Powered by the cutting-edge Silicon Labs MG24 SoC and ESP32-S3 USB bridge, the ZBT-2 delivers lightning-fast responses, ultra-low latency, and seamless smart home control——4x faster than ZBT-1.
  • Dual-Protocol Power in One Device: Enjoy Zigbee 3.0 and Thread connectivity in a single device — natively integrated with Home Assistant’s ZHA and Thread systems. ZBT-2 is fully Matter-ready, future-proofing your entire smart home ecosystem.
  • Extended Range. Exceptional Stability: Equipped with a 4.16 dBi omnidirectional high-gain antenna, ZBT-2 easily penetrates walls and extends coverage across multiple rooms. Its orientation-sensing feedback ensures the antenna always performs at peak efficiency — guided by a gentle LED indicator.
  • Plug-and-Play Setup: Simply plug in the ZBT-2 — Home Assistant automatically detects and configures it for Zigbee or Thread networks. No drivers, no manual pairing — just plug and automate.
  • Local Smart Home Hub: All Zigbee and Thread communication stays within your home network for instant response and maximum privacy.
仕様
Category
Item
Details
Product
Model No.
NC-ZBT-9741
Conformity
CE, FCC, RCM
FCC ID
2A8ZE04
Origin
Made in China
Product Details
SoCs
Silicon Labs MG24
ESP32-S3 (USB-serial bridge)
Power & Data
USB-C
5V DC/500 mA
Supported Protocols
Zigbee 3.0
Thread
Antenna Characteristics
Frequency Range
2400-2483.5 MHz
Peak Gain
4.16 dBi
Transmit Power
10 dBm (Europe)
8 dBm (Rest of world)
Radiation Pattern
Omnidirectional
Antenna Dimensions
Ø 24 mm × H 164 mm
Device Characteristics
Dimensions & Weight
Device: 83 × 83 × 179 mm, 157 g
In box: 227 × 168 × 42 mm, 350g
Material
Polycarbonate plastic
Colors: White & Semi-transparent
Environmental Conditions
Operating Temperature
Indoor use only 0 °C to 65 °C (32 °F to 149 °F)
Humidity
Non-condensing
Keep in a dry environment
Usage Notes
Indoor use only.
Avoid direct sunlight and heat sources to prevent overheating. Keep away from excess dust or moisture.
ハードウェア概要
用途
  • Smart home gateway hubs
Ideal as the core coordinator in your Home Assistant setup. ZBT-2 serves as the brain of your Zigbee or Thread network, connecting lights, sensors, switches, and more into one responsive, unified system.
  • Reliable Connectivity for Every Space
Whether in an apartment, home, or workspace, ZBT-2’s high-gain 4.16 dBi antenna ensures strong, stable communication across rooms and floors. Its intelligent design minimizes interference and maintains consistent performance in any environment.
  • Building a Matter + Thread ecosystem
Future-proof your setup with dual-protocol support. ZBT-2 bridges Zigbee and Thread devices, enabling smooth integration into the Matter ecosystem for next-generation interoperability.
認証
HSCODE8517629990
USHSCODE8517620010
UPC
EUHSCODE8517180000
COOCHINA
部品リスト
Home Assistant Connect ZBT-2 base
×1
Antenna
×1
1.5 m USB Type-C Cable
×1
Quickstart guide
×1
SKU 114993669
Home Assistant Connect ZBT-2 is the next-generation Zigbee & Thread USB radio from Nabu Casa, designed specifically for Home Assistant.It connects via USB-C to your Home Assistant hub (e.g., Green / Yellow / Raspberry Pi) to build a fast, reliable, and fully local smart home network.Up to 4× faster than the previous generation ZBT-1 (SkyConnect), with enhanced RF performance and stronger connections.
JPY¥7756.00
