おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
【Free Shipping |Applicable to all warehouses】
Discount will be automatically applied after selecting the shipping method.If you find that the discount is not applied, please clear the cache and try again.
  • Ready-to-use Home Assistant device: Plug in power and network cables to play, the mobile apps ensure a seamless setup, to enhance your home automation experience
  • One system to control everything: Combine your Apple, Google, Samsung, and Amazon devices with support for hundreds of thousands of other smart devices, which are all in one APP
  • Data localization: Safeguard data privacy through exclusive control and local storage by default
  • Extensive and sustainable Home Assistant ecosystem: Support Home Assistant SkyConnect for Zigbee/Thread, Home Assistant Cloud for voice assistants, as well as third-party accessories to support other smart standards
  • Improved every month by open source: New features and improvements are added every month by the great communities of open-source developers
仕様
Processor
Quad-core Cortex-A55 CPU up to 1.8GHz
RAM
4 GB RAM
Storage
32 GB eMMC
Expansion Slot
SD card slot for recovery purposes only
Ethernet
Gigabit Ethernet
USB Ports
2 x USB 2.0 Type-A host port
Display
1x HDMI for debugging purposes only
Wireless Protocols
Zigbee 3.0 and Matter(with Home Assistant SkyConnect)
Pre-installed Firmware
Home Assistant OS
Power
12 V / 1 A through barrel DC power jack(barrel connector)
LEDs
White (Power), Green (Activity Indicator), Yellow (Home Assistant system state)
Power off Button
Press and hold for 6 seconds to shut down safely,
Press and hold for 12 seconds to force the power off
Enclosure
Large aluminum heatsink, great heat dissipation
Size
111*111*33.6mm
Operating Temperature
0 ~ 40℃
ハードウェア概要
用途
  • Intelligent home control
  • Home Security
  • Energy Management
  • Home Automation Tasks
  • Remote Control
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
1.5m Ethernet Cable
x1
Universal Power Supply 12V1A DC(barrel connector)
x1
Quick Start Guide
x1
Warranty & Safely Information
x1
We are putting the spotlight on Seeed's self-developed Home Assistant-compatible products, offering affiliates 10% commission on referred sales. Sign up to earn more today!
A1: Home Assistant Green is an official hardware solution developed and maintained by the Home Assistant team. Compared with DIY setups or third-party devices, it offers a clearer and more reliable experience in terms of system stability and long-term maintenance. As official hardware, system updates and compatibility support follow a well-defined path, reducing uncertainty over time. A2: Home Assistant Green comes with Home Assistant OS pre-installed and supports a true plug-and-play experience, eliminating the need for manual flashing or complex installation. Its hardware is optimized for 24/7 operation, featuring low power consumption and silent performance, making it well suited for continuous home use. A3: In terms of ecosystem compatibility, Home Assistant Green can be expanded with official accessories to support major smart home protocols such as Zigbee, Thread, and Matter, allowing the system to scale as needs grow. For those looking to quickly build a stable, long-term smart home system, Home Assistant Green is a reliable and low-maintenance choice.
A1: To ensure long-term stable operation of a Home Assistant system, it is recommended to keep the system and integrations regularly updated in order to receive the latest features and security fixes. At the same time, setting up regular backups in advance allows for quick recovery in case of device issues or configuration changes, helping to prevent data loss. A2: From a hardware perspective, the device should be placed in a well-ventilated environment to avoid prolonged operation under high temperatures. When adding new automations or integrations, it is recommended to test them first before rolling them out gradually, so as to minimize any impact on overall system stability. A3: As official hardware, Home Assistant Green receives direct support for system updates from the Home Assistant team. This simplifies ongoing maintenance and helps reduce long-term maintenance effort and complexity.
A1: When setting up a Home Assistant system, the main costs typically come from the core hardware and the smart devices added over time. Core hardware includes the device running Home Assistant, as well as optional protocol coordinators or expansion modules, such as ZBT-2 or ZWA-2, which are used to connect Zigbee, Thread, or Z-Wave devices. The cost of smart devices depends on the specific use case and may include sensors, lights, switches, and other accessories that can be added gradually. A2: In addition to these essential components, there may be optional costs for storage or expansion accessories to increase capacity or functionality. These are not required for basic system operation. A3: Home Assistant Green does not require any additional operating system purchases or software licenses. With a one-time hardware investment, it can be used long term. Its low-power design also helps reduce ongoing electricity costs, making it a cost-effective choice overall.
A1: When choosing a Home Assistant device, it is important to consider performance and stability, especially whether it can run automation tasks reliably 24/7 with minimal maintenance or restarts. A2: Ease of use is equally important. Devices that come with Home Assistant pre-installed and support a true plug-and-play experience can significantly reduce the setup effort, making them more suitable for beginners. A3: For expandability, it is worth checking whether the device supports adding major smart home protocols via USB. For example, Home Assistant Green combined with ZBT-2 or ZWA-2 USB dongles can enable support for Zigbee, Thread, or Z-Wave devices, allowing the system to grow over time. A4: Overall, Home Assistant Green strikes a strong balance between performance, power efficiency, and ease of use. When paired with official expansion accessories, it becomes a reliable solution for long-term home use.
A1: Home Assistant offers official, well-maintained documentation covering hardware installation, system setup, and everyday usage. The Home Assistant documentation center provides step-by-step guides for Home Assistant Green, Yellow, Raspberry Pi, and x86 systems: https://www.home-assistant.io/docs/ A2: For initial setup, the official installation guide and the dedicated Home Assistant Green getting started page provide clear instructions for system deployment and device onboarding: https://www.home-assistant.io/installation/ https://www.home-assistant.io/green/
A1: A Home Assistant Hub is a local control center that runs Home Assistant and is used to centrally manage smart devices from different brands and communication protocols. By using a Home Assistant Hub, local automations and cross-brand device integrations can be implemented, reducing reliance on cloud services and improving system stability and privacy. A2: One option is Home Assistant Green, an official hardware solution with Home Assistant OS preinstalled that can serve as a locally running Home Assistant Hub. It is ready to use out of the box, reducing deployment complexity while preserving the stability and privacy benefits of local operation.
SKU 113110024
The official smart home hub developed and maintained by the Home Assistant team. It comes with Home Assistant OS pre-installed for a true plug-and-play setup and can be expanded to support Zigbee, Thread, and Matter via official accessories.
USD$198.90
product.detail.alsoAdd.title
