製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Average gain dBi: 5dBi
  • Frequency range: 860-930MHz
  • Length of 60cm
  • Robust enough to withstand the harsh outdoor environment
  • Can connect to SenseCAP M1 Indoor Gateway
  • Includes hardware for mounting
  • Comes with a 1m cable
For some applications like in an urban environment or where large stretches of land have to be monitored the normal range of LoRa might not be enough. If you need to increase the range for your LoRa devices, then this outdoor LoRa Fiberglass antenna will be the ideal addition to your LoRa system.  It’s a robust solution to provide extra power and range for outdoor LoRa Base stations. The antenna has an average gain of 6dBi, a length of 60cmand a frequency range from 860-930MHz and it comes with hardware for pole and wall mounting.
The Antenna has an N-J Double tooth connector, and it comes with an N-Female to RP-SMA plug cable so it can be easily connected to the SenseCAP Gateways.
Application
The antenna can be used in any environment where long-range LoRa connections are required.
  • Agriculture
  • Environmental Monitoring
  • Urban Monitoring
Parameters
Frequency
860-930MHz
V.S.W.R
<=2.0
Antenna Gain
5.0 +/-0.8dBi
Efficiency
>=60%
Radiation Pattern
Omni-Directional
Max Input Power
>=2W
Polarization
Linear polarization/ Vertical
Impedance
50 Ohm
Material of Radiator
CU
Material of Plastic
FRP (white light)
Cable Type
RG-141 50Ohm
Connector Type
Operation Temperature
-30°C ~65°C
Storage Temperature
-30°C~65°C
Antenna Color Storage life
< 2 year
Cable length
1m
認証
HSCODE8517707090
USHSCODE8517710000
UPC
EUHSCODE8517620000
COOCHINA
LoRa Fiberglass Antenna, 860-930MHz, 5dBi, 600mm
SKU 318020612
Fibreglass LoRa antenna with gain of  5dBi, frequency range 860-930MHz and 60cm length.
JPY¥5540.00
