製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Average gain dBi: 3dBi
  • Frequency range: 902-928MHz
  • Length: 360mm
  • Robust enough to tolerate outdoor environment and water-proof
  • Compatible with SenseCAP M1 Indoor Gateway
  • Comes with an antenna base (no magnetic)
For some applications like in an urban environment or where large stretches of land have to be monitored the normal range of LoRa might not be enough. If you need to increase the range for your LoRa devices, then this outdoor LoRa Fiberglass antenna will be the ideal addition to your LoRa system. It’s a robust solution to provide extra power and range for outdoor LoRa Base stations. The antenna has an average gain of 3dBi, a length of 360mm, and a frequency range from 902-928MHz. It comes with an antenna base as well.
The Antenna has an N-type male connector, and it comes with an N-type Female to RP-SMA male base so it can be easily connected to the SenseCAP M1 Gateways, which has an RP-SMA female connector.
Frequency
902-928MHz
Impedance
50Ω
VSWR
≤2.5
Gain
≤3dBi
Efficiency
60%
Beamwidth
360°
Connector
N-Type Male
Material
Fiberglass
Length
360mm
Operation Temperature
-20℃~65℃
Efficiency And Gain
Frequency(MHz)
Efficiency(%)
Gain(dBi)
902
79.46
3.07
904
79.73
3.12
906
80.31
3.18
908
80.93
3.24
910
80.80
3.25
912
80.54
3.26
914
80.40
3.27
916
80.92
3.31
918
80.93
3.33
920
79.85
3.26
922
79.38
3.26
924
79.16
3.30
926
78.33
3.26
928
76.70
3.14
Test Unit in Laboratory
Radiation Pattern
認証
HSCODE8517707090
USHSCODE8517710000
UPC
EUHSCODE8517620000
COOCHINA
Fiberglass Antenna Kit; 902-928MHz-3dBi with Antenna Base for Long Range Application
SKU 318020652
Fibreglass LoRa antenna with a gain of 3dBi, frequency range 902-928MHz, and 360mm length, comes with an antenna base, compatible with SenseCAP M1 Indoor Gateway.
Product Type
Products
JPY¥4733.00
