製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
    CFD400 is an industrial-grade cable that provides low signal loss, long working expectations, and qualification for outdoor deployment. It is able to connect to an antenna for better coverage and connect to SenseCAP M1 Indoor Gateway and SenseCAP Outdoor Gateway for better data transmission.
    Frequency Range
    0-6000MHz
    Length
    3 meter ±40mm
    Impedance
    50Ω
    VSWR
    Typical 1.1 @ 900MHz
    ≤1.5 max @ 6GHz
    Insertion Loss
    Typical 0.45db @ 900MHz
    ≤1.5dB max @ 6GHz
    Capacitance
    76pF/m
    Velocity of Propagation
    85%
    Connectors
    Type N Male/Jack
    Type RP SMA Male
    Insulation Resistance
    > 1,000 MΩ
    Bend Radius
    Min 25.4mm
    Voltage Breakdown
     2.5KV
    External Cable Diameter
    10.3mm
    Connectors
    Type N Female
    Type RP-SMA Male
    Mating Cycles
    > 500
    Jacket Material
    PE
    Conductor Material
    Copper
    Binder Material
    Aluminum/PE Tape
    Braid Material
    Tinned copper wire
    Operation Temperature
    -30°C to +65°C
    Environmental
    RoHS
    VSWR
    Insertion Loss
    Mechanical specification
    認証
    HSCODE8544200000
    USHSCODE8544200000
    UPC
    EUHSCODE8471707000
    COOCHINA
    RF Cable; N Female to RP-SMA Male-CFD400-Black-3m; For SenseCAP M1 Indoor Gateway and Fiberglass Antenna
    SKU 321990876
    It is able to connect to an antenna for better coverage and connect to SenseCAP M1 Indoor Gateway and SenseCAP ONE Outdoor Gateway for better data transmission.
    Product Type
    Products
    JPY¥3150.00
