製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • 860–930 MHz Frequency Coverage – Supports wireless connectivity across the 860–930 MHz frequency range.
  • 1.34dBi Peak Gain – Delivers up to 1.34dBi peak gain for stable RF performance.
  • Flexible & Impact-Resistant Design – Flexible TPU construction with an inner steel core helps absorb impact and return to its original shape.
  • RP-SMA Male Connector – Equipped with an RP-SMA Male connector for compatible RF devices.
  • Wide Operating Temperature Range – Designed to operate from -40°C to +85°C.
仕様
ParameterSpecification
Frequency Range860–930 MHz
Peak Gain1.34 dBi
Average Efficiency0.786
VSWR1.52
Input Impedance50 Ω
Radiation PatternOmnidirectional
PolarizationLinear
ConnectorRP-SMA Male
DimensionsΦ9.5 × 170 mm
Operating Temperature-40°C to +85°C
Storage Temperature-40°C to +85°C
Relative Humidity10%–70%
ColorBlack
ComplianceRoHS Compliant
ハードウェア概要
用途
Designed for a wide range of IoT and wireless communication applications, the flexible whip antenna is well suited for mobile equipment, industrial systems, smart city deployments, and emergency communication scenarios.
認証
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
部品リスト
Omnidirectional Flexible Whip Antenna 860–930MHz, RP-SMA Male, 170mmx1
Omnidirectional Flexible Whip Antenna 860–930 MHz, RP-SMA Male, 170 mm
SKU 100010361
An 860–930 MHz omnidirectional flexible whip antenna with 1.34 dBi peak gain and an RP-SMA Male connector. Its flexible TPU body with an inner steel core provides impact resistance and reliable performance for IoT, industrial, automotive, and mobile applications.
JPY¥792.00
