製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
CFD400 is an industrial-grade cable that provides low signal loss, long working expectations, and qualification for outdoor deployment. It is able to connect to an antenna for better coverage and connect to SenseCAP M1 Indoor Gateway and SenseCAP Outdoor Gateway for better data transmission.
Frequency Range
0-6000MHz
Length
5 meter ±50mm
Impedance
50Ω
VSWR
Typical 1.1 @ 900MHz
≤1.5 max @ 6GHz
Insertion Loss
Typical 0.9db @ 900MHz
≤2.5dB max @ 6GHz
Capacitance
76pF/m
Velocity of Propagation
85%
Connectors
Type N Male/Jack
Type RP SMA Male
Insulation Resistance
> 1,000 MΩ
Bend Radius
Min 25.4mm
Voltage Breakdown
 2.5KV
External Cable Diameter
10.3mm
Connectors
Type N Female
Type RP-SMA Male
Mating Cycles
> 500
Jacket Material
PE
Conductor Material
Copper
Binder Material
Aluminum/PE Tape
Braid Material
Tinned copper wire
Operation Temperature
-30°C to +65°C
Environmental
RoHS
VSWR
Insertion Loss
Mechanical Specification
Part list
CFD400 5 meter cable x1
認証
HSCODE8544200000
USHSCODE8544200000
UPC
EUHSCODE8471707000
COOCHINA
RF Cable; N Female to RP-SMA Male-CFD400-Black-5m; For SenseCAP M1 Indoor Gateway and Fiberglass Antenna
SKU 321990877
It is able to connect to an antenna for better coverage and connect to SenseCAP M1 Indoor Gateway and SenseCAP ONE Outdoor Gateway for better data transmission.
Product Type
Products
JPY¥4575.00
