おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • High gain 3dBi dual-band for 868MHz and 915MHz
  • High efficiency vertical polarized monopole
  • Robust hermetic construction for outdoor usage and small compact size for indoor usage
  • Include easy-to-use magnetic support
  • CE RoHS certified
860-930MHz dual-band -3dBi Omnidirectional Indoor/Outdoor Antenna for Long Range, LoRaWAN LongFi and ISM applications.
Fully compatible with technologies, products and services by
Frequency Range860-930MHz
impedance 50Ω
VSWR
1.5 @ 868MHz typical
1.5 @ 915MHz typical
<2.2 max
Gain3dBi
Efficiency Maximum75%
PolarizationLinear Vertical
Radiation pattern360° Omni directional
Physical length295 mm
Radiator MaterialNickel Steel
Covering Material ABS Black
Cable ConnectorRP-SMA Male
Cable TypeRG-58
Cable Length1000 mm
Temperature operation-20℃ to +65℃ / -4℉ to +150℉
WaterproofIP65
VSWR
Antenna Gain
Antenna Efficiency
Radiation Pattern
Dimension
Usage Scenario
認証
HSCODE8517710000
USHSCODE8517710000
UPC
EUHSCODE8531202090
COOCHINA
Long Range Indoor Antenna Kit; 860-930MHz; 3dBi; 295mm
SKU 110991765
860-930MHz dual-band -3dBi Omnidirectional Indoor/Outdoor Antenna for Long Range, LoRaWAN LongFi and ISM applications. SenseCAP M2 Data Only Hotspot and Light Hotspot indoor antenna.
Product Type
Products
JPY¥2359.00
product.detail.alsoAdd.title
