製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Feature
  • Average gain: 5.8dBi
  • Frequency range: 863-870MHz
  • Length of 80cm
  • Robust enough to withstand the harsh outdoor environment
  • Fit for SenseCAP M1/M2 and other Helium hotspots
  • Includes hardware for mounting
  • Comes with a 1m cable
For some applications like in an urban environment or where large stretches of land have to be monitored the normal range of LoRa might not be enough. So If you need to increase the range for your LoRa devices, then this outdoor LoRa Fiberglass antenna will be the ideal addition to your LoRa system.  It’s a robust solution to provide extra power and range for outdoor LoRa Base stations. The antenna has an average gain of 5.8 dBi, a length of 80cm, and a frequency range from 863-870MHz, and it comes with hardware for pole and wall mounting.
The Antenna has an N-J Double tooth connector, and it comes with an N-Female to RP-SMA plug cable so it can be easily connected to the SenseCAP Gateways.
Application
The antenna can be used in any environment where long-range LoRa connections are required.
  • Agriculture
  • Environmental Monitoring
  • Urban Monitoring
Antenna Specification
Frequency
863-870MHz
Impedance
50Ω
VSWR
≤2.5
Gain
5.8±1dBi
Max Efficiency
>75%
Radiation Pattern
Omni-directional
Connector
N-Type Male
Material
Fiberglass
Length
800±10mm
Operation Temperature
-30℃~65℃
Efficiency and Gain
Cable Specification
Frequency Range 0-6000MHz
Impedance50Ω
VSWR<2.0
Insertion loss<0.5dB @900 MHz
Insulation resistance>15 MΩ
Voltage breakdown>500V
External cable diameter5mm
Connector
Type N Female
Type RP-SMA Male
Conductor material
Copper
Binder materialAluminum/PE Tape
Braid materialTinned copper wire
Operation temperature-40°C to + 65°C
Test Unit in Laboratory
Radiation Pattern
VSWR
Part list
Antenna
1*
CFD200 cable 1mt
1*
Mounting Bracket
1*
認証
HSCODE8517707090
USHSCODE8517710000
UPC
EUHSCODE8517620000
COOCHINA
LoRa Fiberglass Antenna Kit For Helium; 863-870MHz; 5.8dBi; 800mm; RF Explorer RFELA-2/58X
SKU 318020690
Fibreglass LoRa antenna with a gain of 5.8 dBi, frequency range 863-870MHz, and 800mm length, comes with a CFD200 cable with 1m length and a mounting brakets, compatible with SenseCAP M1 Indoor Gateway.
JPY¥7898.00
廃番
