おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Plug-and-play bundle: Assembled robot arm kit plus NVIDIA Jetson Orin Nano 8G box pre-installed with Jetpack, allowing plug-and-play deployment.
  • Fully Open-Source: A truly 100% open-source 6+1 DoF robotic arm in terms of hardware and software. It includes BOM lists, hardware drawings, software, and algorithms—everything you need.
  • High-performance motors: 4 Damiao 4310 motors + 3 Damiao4340P high-torque, low-noise motors ensure stable and precise power for the reBot Arm B601-DM.
  • Framework Compatibility: Supports mainstream robotics development frameworks such as ROS1/2, Isaac Sim, and LeRobot.
  • Constant Content Updates: As the project progresses, we will gradually update the latest algorithms and launch a series of completely free courses.
⚠️Buying Guide
This is a fully assembled version, ready to use out of the box. Items pre-selected are essential for smooth robotic arm operation. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a workbench. Please make sure to include one if you do not already have it. All other accessories are optional and can be purchased as needed.
仕様
reBot Arm B601-DM Assembled Kit with Gripper
Degrees of Freedom
6+1
Reach
767mm
607mm(without gripper)
Payload
1.5kg (without gripper, 70% reach recommended)
Joint Range of Motion
J1:±150°
J2:-220 - 0°
J3:-220 - 0°
J4:±90°
J5:±90°
J6:±90°
Gripper:-325° - 0°
Repeatability
0.2 mm
Weight
about 4.7kg
Servos
DM-J4340P-2EC x3
DM-J4310-2EC x4
Operating Temperature
-20°~50°
Power
DC 24V 10A
ROS1
Moveit1
ROS2
Moveit2
Python
Lerobot
Isaac Sim
Pinocchio
Open Source
ハードウェア概要
用途
  • MotorBridge control
Seeed offers Motorbridge, an integrated joint control and robotic arm simulation interface. It delivers intuitive control capabilities and effectively narrows the sim-to-real gap.
  • Teleoperation & Remote Robotics Control
The reBot Arm B601 enables intuitive teleoperation for remote manipulation, data collection, and human-in-the-loop training. Combined with AI robotics frameworks like Hugging Face LeRobot, it supports datasets and pre-trained model and policies, and imitation learning workflows that translate human actions into robotic behaviors, accelerating embodied AI development.
  • Assistive Automation for Home Daily Tasks
The reBot Arm B601 supports the development of assistive robotics for everyday tasks, from pick-and-place to simple household automation. By combining vision and learning-based control, the robot can adapt to unstructured environments and variable objects, helping bring embodied AI into practical, human-centered scenarios.
  • Precision Tasks in Harsh or Constrained Environments
With ±0.2 mm repeatability and stable actuation, the B601 is suited for precise tasks in challenging or unsafe environments. Developers can prototype applications such as inspection, sample handling, or fine manipulation under constrained conditions. Its support for dynamic motion execution enables more reliable interaction with uncertain or sensitive objects. This makes it a strong platform for validating robotics solutions before scaling to industrial systems.
  • Your Physical AI Project Deserves the Spotlight!
Seeed Studio's monthly "Physical AI Project of the Month" is now open for submissions—whether you're building with the reBot Arm (B601-DM/RS) or the SO-ARM (100/101), this is your chance to showcase your work to the global robotics community and get featured by Seeed Studio!
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
部品リスト
reBot Arm
Name
Quantity
Assembled Robotic Arm (with gripper)
1
Hex key wrench set
1
Mouse pad
1
[10% OFF] reBot Arm B601-DM Assembled Kit with Jetson Orin
SKU E26051901
reBotArm B601-DM, the Open-Source Robotic Arm with "Truely Open-Source" as its core, lowers the barrier to Embodied AI learning and development.delivers 1.5kg payloads, up to 767mm reach, and 0.2mm repeatability precision.
Paired with the NVIDIA® Jetson™ Orin™ Nano 8G box reComputer J3011, this bundle forms a complete out-of-the-box edge deployment solution for robotic arms. Simply install dependencies with a single command, and you can quickly get started with robot arm control and field deployment. This bundle delivers a one-stop solution for on-site robotic arm applications, with vision and voice control option.
10% off is automatically applied at checkout.
AI Computing Platform
USD$2407.00
reBot Arm B601-DM Assembled Kit with Gripper (Without Power Supply)x1$1599.00
Power Adapter Kit for reBot Arm B601-DMx1$59.00
reComputer J3011 - Edge AI Computer with NVIDIA® Jetson™ Orin™ Nano 8GB (Support Super Mode)x1$749.00
product.detail.alsoAdd.title
