おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Fully Open-Source: A truly 100% open-source 6+1 DoF robotic arm in terms of hardware and software. It includes BOM lists, hardware drawings, software, and algorithms—everything you need.
  • Detailed Assembly Tutorials: Provide ultra-detailed assembly steps and video tutorials.
  • High-performance motors: 4 DAMIAO 4310 motors + 3 DAMIAO 4340P high-torque, low-noise motors ensure stable and precise power for the reBot Arm B601-DM.
  • Framework Compatibility: Supports mainstream robotics development frameworks such as ROS1/2, Isaac Sim, and LeRobot.
  • Constant Content Updates: As the project progresses, we will gradually update the latest algorithms and launch a series of completely free courses.
⚠️Buying Guide
This is a DIY kit and requires assembly before use. Items pre-selected are essential for smooth robotic arm operation. Feel free to uncheck them if you already have these parts. If you'd like to explore teleoperation, please purchase the "Star Arm 102 (Leader Arm)" and "12V 2A AC/DC Adapter (5-in-1)" together. A mounting G-clamp is required to securely fix the robotic arm to a workbench. All other accessories are optional and can be purchased as needed.
仕様
Black Friday Offer: 2,000 Free SenseCraft Robotics Credits
From Nov 17–30, 2026, purchase an SO-ARM101, reBot Arm B601-DM, or reBot Arm B601-RS and get 2,000 free credits for cloud training and inference in SenseCraft Robotics. Your redemption code will be emailed to you automatically once your payment is complete.
One‑Stop Guided Setup & Cloud‑Powered Robot AI Training
SenseCraft Robotics is an in‑house developed, exclusive platform from Seeed Studio. It delivers an all‑in‑one robot‑AI workflow featuring guided setup, cloud training and lightweight local validation. It lets you finish essential pre‑training steps — device pairing, serial binding, camera binding, calibration check and teleoperation check — all in one place, greatly streamlining your setup for education labs, R&D PoCs and early‑stage robot validation projects.
Degrees of Freedom6+1
Reach767mm
607mm(without gripper)
Payload1.5kg (without gripper, 70% reach recommended)
Joint Range of MotionJ1:±150°
J2:-220° - 0°
J3:-220° - 0°
J4:±90°
J5:±90°
J6:±90°
Gripper:-325° - 0°
Repeatability0.2 mm
Weightabout 4.7kg
ServosDM-J4340P-2EC x3
DM-J4310-2EC x4
Operating Temperature-20°~50°
PowerDC 24V 15A
ROS1✅
Moveit1✅
ROS2✅
Moveit2✅
Python✅
Lerobot✅
Isaac Sim✅
Pinocchio✅
Open Source✅
ハードウェア概要
用途
Teleoperation & Remote Robotics Control
The reBot Arm B601 enables intuitive teleoperation for remote manipulation, data collection, and human-in-the-loop training. Combined with AI robotics frameworks like Hugging Face LeRobot, it supports datasets and pre-trained model and policies, and imitation learning workflows that translate human actions into robotic behaviors, accelerating embodied AI development.
Assistive Automation for Home Daily Tasks
The reBot Arm B601 supports the development of assistive robotics for everyday tasks, from pick-and-place to simple household automation. By combining vision and learning-based control, the robot can adapt to unstructured environments and variable objects, helping bring embodied AI into practical, human-centered scenarios.
Precision Tasks in Harsh or Constrained Environments
With ±0.2 mm repeatability and stable actuation, the B601 is suited for precise tasks in challenging or unsafe environments. Developers can prototype applications such as inspection, sample handling, or fine manipulation under constrained conditions. Its support for dynamic motion execution enables more reliable interaction with uncertain or sensitive objects. This makes it a strong platform for validating robotics solutions before scaling to industrial systems.
Your Physical AI Project Deserves the Spotlight!
Seeed Studio's monthly "Physical AI Project of the Month" is now open for submissions—whether you're building with the reBot Arm (B601-DM/RS) or the SO-ARM (100/101), this is your chance to showcase your work to the global robotics community and get featured by Seeed Studio!
Join our Discord community for discussions and support:
https://discord.gg/wsfpnbm3cU
部品リスト
This parts list only shows items included in the default selected purchase options:
(1) reBot Arm B601-DM Body Motor Kit
Item Name
Quantity
DAMIAO 4310 Actuator Motor
3
DAMIAO 4340P Actuator Motor
3
DAMIAO USB-CAN Driver Board
1
XT30 2+2 Power Separation Board
1
BCCA4011 XT30 (2+2) Straight-to-Right-Angle 30CM Cable
1
BCCA4012 XT30 (2+2) Dual Right-Angle 35CM Cable
1
BCCA4012 XT30 (2+2) Dual Right-Angle 20CM Cable
2
BCCA4009 XT30 (2+2) Dual Straight 30CM Cable
3
Mouse Pad
1
USB cable
1
(2) reBot Arm B601-DM Body Structure Kit
Item Name
Quantity
Metal Parts
21
3D Printed Parts
17
Screw KM3x7mm
67
Screw KM3x9mm
31
Screw KM3x12mm
23
Screw KM3x16mm
17
Screw KM3x8mm
8
Screw KA3x12mm
59
Screw HM4x75mm
4
Dowel Pin D3xL8mm
3
Dowel Pin D4xL7mm
7
Dowel Pin D4xL10mm
7
Dowel Pin D4xL14mm
4
Hex Key Wrench Set
1
(3) reBot Arm B601-DM Gripper Kit
Item Name
Quantity
Metal Parts
10
3D Printed Parts
5
1
Power Cable;XT30-(2+2)-Female to XT30-(2+2)-Female-200mm
1
Standard Parts & Consumables
4
Screw KM3x7mm
15
Screw KM3x16mm
11
Screw KA3x12mm
11
HM3x6mm
11
HM3x12mm
10
HM3x26mm
9
(4)reBot Arm B601-DM Power Adapter
Item Name
Quantity
AC/DC Adapter 24V 15A 3-in-1(CN, US, EU Plugs Included)
1
reBot Arm B601-DM Unassembled Kit
SKU E26041401
Engineered for true open-source robotics. The reBot Arm B601-DM combines a 1.5 kg rated payload, ±0.2 mm repeatability, and a fully open-source ecosystem—including hardware, software, CAD, BOM, SDK, and tutorials—to accelerate sim-to-real learning, teleoperation, and Physical AI development.
Robot Arm
Assembly Type
AI Computing Platform
USD$1256.00
reBot Arm B601-DM Body Motor Kitx1$829.00
reBot Arm B601-DM Body Structure Kitx1$169.00
reBot Arm B601-DM Gripper Kitx1$199.00
Power Adapter Kit for reBot Arm B601-DMx1$59.00
product.detail.alsoAdd.title
