製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Price Increase Announcement
Date: February 28, 2026
Due to surging demand for modules and SSDs, prices for reComputer and reServer Jetson devices will increase by approximately $50 to $400 in the coming weeks. Please confirm your requirements and place your orders promptly to secure your stock.
Note:
If you want to use SSDs with reComputer, we only recommend you choose the 128GB, the 256GB, and the 512GB versions from Seeed, because some of the SSDs in the market will work with this product under a particular JetPack version and some will not work with a different JetPack version. Even the official NVIDIA dev kits have the same behavior with SSDs.
仕様
Jetson Orin Nano System on Module
Al Performance
reComputer Industrial J3011 - Orin Nano 8GB, 40 TOPS
reComputer Industrial J3010 - Orin Nano 4GB, 20 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
512-core NVIDIA Ampere architecture GPU with 16 Tensor Cores
CPU
6-core Arm® Cortex®-A78AE v8.2 64-bit CPU 1.5MB L2 + 4MB L3
Memory
8GB 128-bit LPDDR5 68 GB/s
4GB 64-bit LPDDR5 34 GB/s
Video Encoder
1080p30 supported by 1-2 CPU cores
Video Decoder
1x 4K60 (H.265) | 2x 4K30 (H.265) | 5x 1080p60 (H.265) | 11x 1080p30 (H.265)
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
Networking
Ethernet
1x LAN1 RJ45 GbE PoE(PSE 802.3 af 15 W)
1x LAN2 RJ45 GbE (10/100/1000Mbps)
I/O
USB
3x USB3.2 Gen1,
1x USB2.0 Type C (Device mode),
1x USB2.0 Type C For Debug UART & RP2040
Display
1x HDMI Type A; 1x DP
Fan
1x 4 pin 1.25mm Fan Connector (5V PWM)
DI/DO
4x DI, 4x DO, 3x GND_DI, 2x GND_DO, 1x GND_ISO,1x CAN
COM
1x DB9 (RS232/RS422/RS485)
SIM
1x Nano SIM card slot
Expansion
Mini PCIe
Mini PCIe for 4G/LoRaWAN® (Module optional)
WiFi
Support SMD Wi-Fi/Bluetooth (Customized production, please contact [email protected])
M.2 Key B
M.2 Key B support 4G/5G (Module optional)
Fan
Fanless, passive heatsink
1*4 -pin 1.25mm Fan connector(5V PWM)
TPM
1x TPM 2.0 connector (Module optional)
RTC
1x RTC socket, 1* RTC 2-pin
Camera
2x CSI (2-lane 15pin)
Power
DC 12V-24V Terminal block 2 pin
19V Power Adapter(without power cord)
Mechanical
Dimensions (W x D x H)
159mm x 155mm x 57mm
Weight
1.57kg
Installation
Desk, DIN rail, wall-mounting, VESA
Environment
Operating Temperature
-20 ~ 60°C with 0.7m/s
Operating Humidity
95% @ 40 °C (non-condensing)
Vibration
3 Grms @ 5 ~ 500 Hz, random, 1 hr/axis
Shock
50G peak acceleration (11 msec)
Warranty
2 Years
IP Rating
IP40
ハードウェア概要
Full System
Carrier Board
Desktop, Wall Mount, DIN Rail, VESA mount to fit in anywhere
用途
Application Fields:
AI Video Analytics
Machine Vision
Autonomous Mobile Robot (AMR)
Generative AI
● Capable of Bringing Generative AI to the Edge
Now you can build AI agents capable of processing large amounts of live or archived videos and images with Vision-Language Models (VLM) such as LLaVA, this new AI agents help nearly every industry summarize, search, and extract actionable insights from video using natural language.
● Build Multi-streams AI Video Analytics
For building video analytics, Jetson Orin NX incorporates the NVIDIA Multi-Standard Video Decoder. This video decoder accelerates video decode, supporting low resolution mobile content, Standard Definition (SD), High Definition (HD) and UltraHD (8K, 4K, etc.) .
● Fastest Way to Deploy Generative AI and Computer Vision Models
We have jetson-example prepared for you! It offers one-line deploy projects edge AI applications of generative AI including Ollama, Llama3; computer vision including YOLOv8, and others. We have configured all environment for you to provides single command deployment of projects.
認証
HSCODE8471504090
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
reComputer Industrial J3011 (System Installed)
x1
Mounting bracket
x2
DIN rail bracket
x1
Bracket screw
x4
16-Pin Terminal Block for DIO
x1
19V Power adapter (power cord sold separately)
x1
2-Pin Terminal block power connector
x1
Note:
Please note that the product comes with a power adapter, but does not include a AC cloverleaf power cord. Kindly purchase the appropriate AC cloverleaf power cord based on your local power socket specifications.
reComputer Industrial J3011- Fanless Edge AI Device with Jetson Orin™ Nano 8GB
SKU 110110193
reComputer Industrial J3011 features NVIDIA Jetson Orin™ Nano 8GB module for 40 TOPS AI performance and supports hybrid connectivities including 2 RJ-45 Ethernet ports, 1 RS232/422/485 & CAN port, etc. Fanless with versatile mounting options allows deployment for more harsh environments and heavier loads.
Processor
Memory
JPY¥158116.00
