製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Up to 16-level grayscale clarity: Support 2 to 16 levels of grayscale (1-4 bits), delivering clear and refined visuals for text and graphics.
  • Ultra-Low Power Consumption: The ePaper consumes power only during updates, resulting in longer battery life and greater energy efficiency.
  • Plug&Play with XIAO ePaper Driver Board: Optimized for the XIAO ePaper Display Board EE03, powered by the XIAO ESP32-S3 Plus, featuring a reserved battery connector and user button to accelerate prototyping and project development.
  • Wide Range of Applications: Supports high-speed refresh for low-latency updates with a TTL parallel interface (multi-line, high-throughput) — perfect for e-paper readers and digital notebooks.
Seamless Setup and Customization for Your ePaper Display
This ePaper display is designed to work seamlessly with any standard 40-pin driver board. We recommend the XIAO ePaper Display Board EE03.
To make things even easier, we’re introducing SenseCraft HMI—a no-code, AI-powered platform that allows you to quickly design and customize your user interface. Drag and drop elements, choose templates, or let AI generate the perfect layout for you.Get started today and create your ideal display experience with ease!
仕様
Parameter
Type
Dot Matrix
Size
10.3 inch
Active Area(mm)
157.25(V)×209.66(H)
Resolution
1404 (V)×1872 (H)
Pixel Pitch(mm)
112 × 112
Display Color
Black, White
Interface
TTL
Connector
40 Pin FPC, 0.5mm Pitch
Grayscale
16
Driver Mode
Support XIAO/Arduino/MicroPython
Drawing
Support GUI Drawing
Outline Dimension(mm)
174.4(V) × 216.7(H) × 0.78(D)
Weight(g)
60±7
ハードウェア概要
用途
  • Reading equipment
  • Retail shelf labels
  • Conference room signage
  • logistics tracking boards
  • Smart home dashboards
認証
HSCODE8524999010
USHSCODE8524119000
UPC
EUHSCODE8471707000
COOCHINA
部品リスト
10.3-inch Monochrome ePaper Display
×1
10.3 Monochrome eInk / ePaper Display with 1404 ×1872 Pixels, TTL interface, Support XIAO/Arduino
SKU 100071485
The 10.3 inch ePaper Display offer a high-quality, low-power solution for a wide range of applications. The model features a 1404 ×1872 resolution, black and white display with a diagonal size of 10.3 inches. With a fast refresh rate and excellent contrast, this display is ideal for e-readers, digital notebooks, and other portable devices.
JPY¥13454.00
