製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Exceptional Readability: The display's reflective properties ensure effortless legibility of text and images in different lighting environments.
  • Ultra-Low Power Usage: The E-paper only consumes power during updates, leading to prolonged battery life and efficient energy use.
  • Wide Viewing Angles: Greater than 170 degrees, unaffected by light direction.
  • Flexibility and Portability: Allowing bending and curling for versatile applications.
  • Eye-Friendly and Heat-free: Eliminate glare, providing a comfortable viewing experience while remaining cool without generating heat
The 2.13-inch E-Paper Display is a flexible substrate-based display with a 212x104 pixel active area and 1-bit white/black full display capabilities. It features high contrast, high reflectance, ultra-wide viewing angle, ultra-low power consumption, and pure reflective mode. The display is bi-stable, operates in commercial temperature range, and has landscape and portrait modes. It is available in COG package IC thickness 280um and has an on-chip display RAM and waveform stored in On-chip OTP. The display also has a serial peripheral interface available, an on-chip oscillator, an on-chip booster, and regulator control for generating VCOM, Gate, and source driving voltage.
What is an E-Paper?
E-Paper, short for Electronic Paper, is a type of display technology that aims to mimic the appearance of traditional paper and ink. It's designed to provide high contrast and readability in various lighting conditions, including direct sunlight, without the need for a backlight. E-Paper displays use tiny microcapsules containing charged particles suspended in a liquid to produce images. When an electric field is applied, the particles move to the top or bottom of the microcapsules, resulting in different shades or colors being visible to the viewer. E-Paper is often used in e-readers, electronic shelf labels, smartwatches, and other devices where energy efficiency and readability are essential.
Advantages Over Traditional Displays
E-Paper displays offer advantages over traditional displays, including better readability like paper, visibility in sunlight, low energy consumption, thin design, wide viewing angles, and longer battery life. They are ideal for portable devices and environments where glare and power efficiency matter.
Parameters
Details
Model No.
GDEW0213I5FD
Type
Dot Matrix
Size
2.13 inch
Active Area(mm)
48.55 x 23.71
Resolution
212 x 104 pixels
Pixel Pitch(mm)
0.229 x 0.228
Display Color
Black, White
Grayscale
4
Partial Refresh Time
0.3s
Full Refresh Time
3s
Interface
SPI
Viewing Angle
>170°
Operating Voltage
3.3V
Operating Temperature
0-50°C
Driver Mode
Support XIAO/STM32/Arduino/MicroPython
Drawing
Support GUI Drawing
Power Consumption
26.4mW (typ.)
Standby Consumption
0.0165mW
Outline Dimension(mm)
59.2 x 29.2 x 0.3
Weight
3.2g
Hardware Overview
Applications
  • Reading equipment
  • Mobile device
  • Electronic tags and price tags
  • Smart Wearables
  • Electronic Shelf Labels
  • Smart Card
Part List
2.13 Flexible Monochrome ePaper Display
×1
ePaper Display FAQ
Precautions for E-paper Display
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
2.13" Flexible Monochrome eInk / ePaper Display with 212x104 Pixels, SPI interface, Support XIAO/Arduino/STM32
SKU 104990847
The 2.13 inch E-paper Display is a flexible substrate-based display with a 212x104 pixel active area and 1-bit white/black full display capabilities. It features high contrast, ultra-low power consumption, and pure reflective mode.
JPY¥1884.00
廃番
