おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Plug & Play with XIAO ePaper Driver Boards: Natively compatible with a range of 24-pin ePaper displays via the ePaper Display Board, these ready-to-use controller boards offer features such as an optional battery connector and a user button to accelerate prototyping and project development.
  • Exceptional Readability: The display's reflective properties ensure effortless legibility of text and images in different lighting environments.
  • Ultra-Low Power Consumption: The ePaper consumes power only during updates, resulting in longer battery life and greater energy efficiency.
  • Eye-Friendly and Heat-free: Eliminate glare, providing a comfortable viewing experience while remaining cool without generating heat.
Seamless Setup and Customization for Your ePaper Display
This ePaper display is designed to work seamlessly with any standard 40-pin driver board. We recommend the XIAO ePaper Display Board EE04 or XIAO ePaper Display Board EE05.
To make things even easier, we’re introducing SenseCraft HMI—a no-code, AI-powered platform that allows you to quickly design and customize your user interface. Drag and drop elements, choose templates, or let AI generate the perfect layout for you.Get started today and create your ideal display experience with ease!
仕様
Parameters
Details
Driver IC
SSD1680
Type
Dot Matrix
Size
2.13 inch
Active Area(mm)
48.55 x 23.7046
Resolution
122 x 250 pixels
Pixel Pitch(mm)
0.1943 x 0.1942
Display Color
Black, White, Yellow and Red
Interface
SPI
Connector
24 Pin FPC, 0.5mm Pitch
Viewing Angle
>170°
Operating Voltage
3.3V
Operating Temperature
0-40°C
Driver Mode
Support XIAO/Arduino/MicroPython
Drawing
Support GUI Drawing
Power Consumption
9.9mW (typ.)
Standby Consumption
0.003mW
Outline Dimension(mm)
59.2 x 29.2 x 1.00
Weight
3.2g
ハードウェア概要
用途
  • Reading equipment
  • Mobile device
  • Electronic tags and price tags
  • Smart Wearables
  • Electronic Shelf Labels
  • Smart Card
Supported ePaper Display Board
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
Battery Power ON/OFF
Button
1x Reset,
3x User
1x Reset,
3x User
Extension IO Port
SenseCraft HMI
認証
HSCODE8517180050
USHSCODE8517180050
UPC
EUHSCODE8471707000
COOCHINA
認証
2.13" Quadruple Color ePaper Display
×1
2.13" Quadruple Color eInk / ePaper Display with 122x250 Pixels, additional yellow and red display, SPI interface, Support XIAO/Arduino
SKU 104990846
The 2.13-inch e-paper display module offer 122x250 resolution, where it can present images in black, white, yellow, and red. The display achieves a 25-second full-screen refresh for efficient performance which is perfect for e-readers, wearables, and portable devices.
JPY¥1188.00
product.detail.alsoAdd.title
