製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Plug & Play with XIAO ePaper Driver Boards: Natively compatible with a range of 24-pin ePaper displays via the ePaper Display Board, these ready-to-use controller boards offer features such as an optional battery connector and a user button to accelerate prototyping and project development.
  • Exceptional Readability: The display's reflective properties ensure effortless legibility of text and images in different lighting environments.
  • Ultra-Low Power Consumption: The ePaper consumes power only during updates, resulting in longer battery life and greater energy efficiency.
  • Eye-Friendly and Heat-free: Eliminate glare, providing a comfortable viewing experience while remaining cool without generating heat.
Seamless Setup and Customization for Your ePaper Display
This ePaper display is designed to work seamlessly with any standard 40-pin driver board. We recommend the XIAO ePaper Display Board EE04 or XIAO ePaper Display Board EE05.
To make things even easier, we’re introducing SenseCraft HMI—a no-code, AI-powered platform that allows you to quickly design and customize your user interface. Drag and drop elements, choose templates, or let AI generate the perfect layout for you.Get started today and create your ideal display experience with ease!
What is an E-Paper?
E-Paper, short for Electronic Paper, is a type of display technology that aims to mimic the appearance of traditional paper and ink. It's designed to provide high contrast and readability in various lighting conditions, including direct sunlight, without the need for a backlight. E-Paper displays use tiny microcapsules containing charged particles suspended in a liquid to produce images. When an electric field is applied, the particles move to the top or bottom of the microcapsules, resulting in different shades or colors being visible to the viewer. E-Paper is often used in e-readers, electronic shelf labels, smartwatches, and other devices where energy efficiency and readability are essential.
Advantages Over Traditional Displays
E-Paper displays offer advantages over traditional displays, including better readability like paper, visibility in sunlight, low energy consumption, thin design, wide viewing angles, and longer battery life. They are ideal for portable devices and environments where glare and power efficiency matter.
仕様
Parameters
Details
Driver IC
SSD1683
Type
Dot Matrix
Size
4.2 inch
Active Area(mm)
84.8 x 63.6
Resolution
400 x 300 pixels (DPI:120)
Pixel Pitch(mm)
0.212 x 0.212
Display Color
Black, White
Max Grayscale
4
Interface
SPI
Connector
24 Pin FPC, 0.5mm Pitch
Viewing Angle
>170°
Operating Voltage
3.3V
Operating Temperature
0-50°C
Driver Mode
Support XIAO/Arduino/Micropthon
Drawing
Support GUI Drawing
Power Consumption
18.48mW (typ.)
Standby Consumption
0.0165mW
Outline Dimension(mm)
91 x 77 x 1.2
Weight
3.2g
ハードウェア概要
用途
  • Reading equipment
  • Mobile device
  • Electronic tags and price tags
  • Smart Wearables
  • Electronic Shelf Labels
  • Smart Card
Supported ePaper Display Board
Product
Processor
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
XIAO
ESP32-S3 Plus
XIAO
nRF52840 Plus
N/A(Compatible with XIAO Series)
Compatible Displays
24 Pin ePaper
24 Pin ePaper
50 Pin ePaper
24 Pin ePaper
Battery Connector
JST 2.0mm
JST 2.0mm
JST 2.0mm
Battery Power ON/OFF
Button
1x Reset,
3x User
1x Reset,
3x User
Extension IO Port
SenseCraft HMI
認証
HSCODE8543709990
USHSCODE8531200040
UPC
EUHSCODE8543709099
COOCHINA
部品リスト
4.2" Monochrome ePaper Display
×1
4.2" Monochrome eInk / ePaper Display with 400x300 Pixels, SPI interface, Support XIAO/Arduino
SKU 104990857
The 4.2-inch E-paper Display offers a high-quality, low-power solution for a wide range of applications. The model features a 400x300 resolution, black and white display with a diagonal size of 4.2 inches. With a fast refresh rate and excellent contrast, this display is ideal for e-readers, smart wearables, and other portable devices.
JPY¥3158.00
