CM4 Router Board is an expansion board based on the Raspberry Pi Compute Module 4. It brings Raspberry Pi CM4 two full-speed gigabit network ports and the "RTL8111E" controller chip offers better performance, lower CPU usage, and higher stability for a long time of work compared with a USB network card.
This CM Router Board is highly scalable with rich IO peripherals. There is a USB2.0 interface that can be connected to a USB flash driver, USB keyboard, printers, WIFI modules, etc. The standard HDMI interface can help you configure the device and display operating information conveniently. Moreover, the 5V DC Fan interface supports a 5V cooling fan and also the PWM protocol, which means you can control the speed of fan blades via a PWM signal.
An OLED(0.91 inches) screen that will help you to customize your Router Board's information display style. The board still retains the characteristic GPIO pin header of Raspberry Pi, which makes it applicable for connecting other hat boards such as Pi hats, sensors, PoE hat boards, cooling fans, etc.
Furthermore, the board supports a user-friendly development environment since it provides OpenWRT open-source router system. After a simple setup, it can be used as a router. It is also compatible with Raspberry OS, Ubuntu Server, and other Raspberry Pi systems, even you can make this router board a retro game machine at home.
The powerful performance of BCM2711 4 core 1.5GHz Cortex-A72 and the rich software support in the Raspberry Pi community make this board a solid foundation for building high-performance gateways, smart routers, and home IoT platforms. If you need multiple LAN network ports like common routers, it is recommended to use a gigabit switch to expand the network ports, which will not affect its Internet performance. It can also be connected to peripherals and used as a mini-NAS, wireless network bridge, or mini server which can be controlled via terminal.
A router is a piece of hardware that connects a Local Area Network (LAN) to other networks. In most cases, this “other network” is known as a Wide Area Network (WAN), or none other than the Internet. The router is very much the “administrator” of this local network and plays an important role in managing connected devices. While their primary role is true to simply coordinate connections and forward data, routers are very much small computers themselves.
1. Increase Network Bandwidth and Performance
While the Raspberry Pi is definitely weaker in comparison to a full-fledged desktop or laptop, its Broadcom CPU is certainly more than enough when it comes to network routing. Thus, a Raspberry Pi router will surely be a boost to your network and give you greater internet speeds!
2. Improve Network Security
With a Raspberry Pi Router, you’ll be able to choose from free, open-source operating systems like OpenWrt that are community reviewed and maintained for security!
3. Enjoy Additional Features
With the accompanying hardware and I/O, using a Raspberry Pi as a router grants you flexibility in adding more features.
Read this blog for more details.
| Compatible Module | Raspberry Pi Compute Module 4 series |
| POE HAT |
| Interfaces |
| Ethernet | High-performance Gigabit ethernet controller RTL8111E chip, JXD 2111x G2406s chip as an isolation transformer
| GPIO | 40Pin GPIO compatible with Raspberry Pi |
| Power Supply | USB-C(Type-C) 5V/3A interface |
| Operating Temperature | 0℃~80℃ |
| Dimension | 146 x 80mm |
Smart Office
Smart Home
IoT
mini Server
Note
Please check the introduction of peripheral interfaces and pin description in the 'Documents' part below.
Also, how to set up your router board and Openwrt could be found in the 'Documents' part below.
| CM4 router board | 1 |
