おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
  • Dual encoders: The output shaft provides single-turn absolute position feedback, eliminating the risk of absolute position loss after power failure.
  • Integrated motor-driver design: Boasts a compact structure and high integration.
  • Supports visual debugging via the host computer, as well as firmware upgrades.
  • Can feed back motor information (such as speed, position, torque, and temperature) via the CAN bus.
  • Equipped with dual-temperature protection
  • Supports trapezoidal acceleration/deceleration in position mode
仕様
Parameter
DM4310
DM4340P
Rated Voltage
24V
24V
Rated Current
2.5A
2.5A
Peak Current
7.5A
8A
Rated Torque
3NM
9NM
Peak Torque
7NM
27NM
Rated Speed
120rpm
36rpm
No-Load Max Speed
200rpm
52rpm
Gear Ratio
10: 1
40:1
Number of Pole Pairs
14
14
Phase Inductance
340μH
340μH
Phase Resistance
650mΩ
880mΩ
Outer Diameter
56mm
57mm
Height
46mm
56.5mm
Motor Weight
Approx. 300g
Approx. 375g
Encoder Resolution
14 bits
Number of Encoders
2
Encoder Type
Magnetic Encoder (Single-turn)
Control Interface
CAN@1Mbps
Tuning Interface
UART@921600bps
Control Modes
MIT Mode; Speed Mode; Position Mode
Protection
● Driver Over-temperature Protection: Triggers at 120°C, motor exits "Enable Mode"- Motor
● Over-temperature Protection: Recommended ≤100°C (customizable), motor exits "Enable Mode" when exceeded
● Motor Over-voltage Protection: Recommended ≤32V (customizable), motor exits "Enable Mode" when exceeded
● Communication Loss Protection: Motor exits "Enable Mode" if no CAN command is received within the set period
● Motor Over-current Protection: Recommended ≤9.8A (customizable), motor exits "Enable Mode" when exceeded
● Motor Under-voltage Protection: Motor exits "Enable Mode" if supply voltage < set value (recommended ≥15V)
ハードウェア概要
用途
OpenArm
OpenArm is an open-source 7DOF humanoid arm designed for physical AI research and deployment in contact-rich environments. All hardware and software are completely open-source and ready for you to build, hack, and deploy!
I2RT
Ready to deploy and built on a fully open-source codebase, giving you complete transparency and customization. Designed for rapid integration, community-driven improvements, and scalable real-world applications.
ドキュメント
認証
HSCODE8501310000
USHSCODE8501316000
UPC
EUHSCODE8501109390
COOCHINA
部品リスト
6010 Motor
x1
XT30(2+2)
x1
Damiao 4310 Actuator Motor, CAN, OpenArm, ROS2, Python, C++
SKU 100033983
The Damiao 43-series CAN bus joint motors have been widely adopted in numerous open-source robotic arm projects such as OpenArm and I2RT. Featuring dual encoders and an integrated motor-driver design, they boast a compact structure and high integration. Comprehensive technical resources are available, including C++, Python, and ROS 1/2 support packages.
USD$120.00
product.detail.alsoAdd.title
