製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
The Grove - Gas Sensor(MQ2) module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, smoke and so on. Based on its fast response time. measurements can be taken as soon as possible. Also, the sensitivity can be adjusted by the potentiometer.
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
  • Wide detecting scope
  • Stable and long lifetime
  • Fast response and High sensitivity
Documents
More information about the gas sensor, please refer to this manual.
認証
HSCODE9027900000
USHSCODE9027908800
UPC841454108351
EUHSCODE9013101000
COOCHINA
技術詳細
Dimensions130mm x90mm x32mm
WeightG.W 16g
BatteryExclude
部品リスト
Grove - Gas Sensor(MQ2)1
Grove cable1
SKU 101020055
Fast response Adjustable sensitivity Covers LPG, i-butane, methane, alcohol, Hydrogen etc Useful for gas leakage detecting Grove connector compatible
JPY¥1251.00
