おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
Tip
We've released the Seeed Gas Sensor Selection Guide, it will help you choose the gas sensor that best suits your needs.
How to choose a gas sensor?
The Grove - Gas Sensor module is useful for gas leakage detecting(in home and industry). It can detect LPG, i-butane, methane, alcohol, Hydrogen, smoke and so on. Measurements can be taken as soon as possible based on its fast response time. Also, the sensitivity can be adjusted by the potentiometer.
There are different gas detectors for sale, like  MQ2, MQ3, MQ5, and MQ9. Below is a contrast table of them.
SymbolMQ-2MQ-3MQ-5MQ-9
Detect Gas Combustible Gas、Smoke Alcohol Vapor LPG, Natural Gas, Town Gas Carbon Monoxide, Coal Gas, Liquefied Gas
Detect Concentration 300-10000ppm 0.04-4mg/L Alcohol 300-10000ppm 10-1000ppmCO;100-10000PPm Gas
Note
Hot-swapping the grove may lead to IC burnout, please turn off the power of the main board before swapping grove.
  • High sensitivity to Combustible gas in a wide range
  • Stable performance, long life, low cost
  • Fast response
  • Wide detection range
  • Simple drive circuit
For all Grove users (especially beginners), we provide you guidance PDF documents. Please download and read through Preface - Getting Started and Introduction to Grove before your using of the product.
One More Thing
認証
HSCODE9027900000
USHSCODE9027908800
UPC841454108344
EUHSCODE9013101000
COOCHINA
技術詳細
Dimensions130mm x90mm x21mm
WeightG.W 14g
BatteryExclude
部品リスト
Grove - Gas Sensor(MQ3)1
SKU 101020006
How to choose a gas sensor ?The Grove - Gas Sensor module is useful for gas leakage detecting(in home and industry)
USD$2.90
product.detail.alsoAdd.title
