This infrared thermometer module has a single-point medical-grade infrared temperature sensor (MLX90641), which can detect the temperature of objects with an accuracy of ±0.2°C in the body temperature range. At room temperature, the surface temperature of the measured object can reach an accuracy of ±0.5°C in a wide range. The module can use the I2C protocol to obtain data from the camera. The field of view (FOV) of this sensor is 35°, the temperature measurement range is -70°C~380°C, and the working temperature is that the sensor's Ta value is between -40°~85°.
| Specification | Details |
| FOV | 35° |
| Measurement accuracy | ±0.2°C(body temperature range) / ±0.5°C |
| Measuring range | -70°C~380°C(object temperature) |
| Senser operating temperature | Ta is between -40°~85° |
| Refresh Rate | 0.5Hz ~ 64Hz |
| Interface | I2C |
| Voltage | 3.3V-5V |
| Current | ~18mA |
1 x Grove - Single-Point Infrared Thermometer - MLX90614 DCC with 35° FOV
The infrared thermomometer module has a single-point medical-grade infrared temperature sensor (MLX90641), which can detect the temperature of objects with an accuracy of ±0.2°C in the body temperature range. At room temperature, the surface temperature of the measured object can reach an accuracy of ±0.5°C in a wide range. The module can use the I2C protocol to obtain data from the camera. The field of view (FOV) of this sensor is 35°, the temperature measurement range is -70°C~380°C, and the working temperature is that the sensor's Ta value is between -40°~85°.
