おすすめ
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
説明
  • Single-point medical-grade infrared temperature sensor (MLX90614)
  • Wide temperature measurement range (-70℃~380℃)
  • Narrow field-of-view (5°) for accurate measurements
  • I2C Grove interface for easy communication with an MCU
This Infrared Thermometer module is equipped with a single-point medical-grade infrared temperature sensor (MLX90614), which can detect the temperature of objects with an accuracy of ±0.2°C in the body temperature range. At room temperature, the surface temperature of the measured object can reach an accuracy of ±0.5°C in a wide range. The module can use the I2C protocol to obtain data from the camera. The field of view (FOV) of this sensor is 5°, the temperature measurement range is -70°C~380°C, and the working temperature is that the sensor's Ta value is between -40°~85°.
Specifications
SpecificationDetails
FOV5°
Measurement accuracy±0.2°C
Measuring range-70°C~380°C(object temperature)
Senser operating temperatureTa is between -40°~85°
Refresh Rate0.5Hz ~ 64Hz
InterfaceI2C
Voltage3.3V-5V
Current~18mA
1 x Grove - Thermal Imaging Camera - MLX90614 DCI IR Array with 5° FOV
認証
HSCODE9031900090
USHSCODE9031902100
UPC
EUHSCODE9013101000
COOCHINA
Grove - Single-Point Infrared Thermometer - MLX90614 DCI with 5° FOV
SKU 101020894
USD$39.00
廃番
product.detail.alsoAdd.title
