必須オプションを選択してください
x1
製品詳細
Wiki & 学習
レビュー
PDF をダウンロード
特長
Note
  • Lumeo AI Gateway is powered by Lumeo software pre-built reComputer industrial hardware.
  • For hardware information, please download our datasheet and visit wiki page.
Powerful Edge AI Gateway:
  • Powered by NVIDIA Jetson Orin™ with 100 TOPS AI performance. Please see the hardware model difference in the following hardware comparison table.
  • Rich connectivity: 2 RJ-45 Ethernet ports, 1 RS232/422/485 & CAN port, 4x Isolated DI/DO.
  • Fanless design, versatile mounting (-20 to 60 ℃).
Effortless Device Configuration:
  • User-friendly web interface
  • Device discovery using MDNS/Windows Explorer.
  • Pre-installed Lumeo software for quick provisioning.
Cloud-based, Large-Scale Device Management:
  • Supports Allxon Remote Edge AI Device Management Service.
  • OOB Power Cycling for instantly resolving system errors and unresponsive devices.
  • Automatic Fleet Provisioning for deployment and customized BSP OTA update for maintenance.
仕様
Jetson Orin NX System on Module
AI Performance
Orin NX 16GB - 100 TOPS
Orin Nano 8GB - 40 TOPS
GPU
1024-core NVIDIA Ampere architecture GPU with 32 Tensor Cores
CPU
8-core Arm® Cortex®-A78AE
6-core Arm® Cortex®-A78AE
Memory
16GB 128-bit LPDDR5
8GB 128-bit LPDDR5
Video Encode
1x 4K60 (H.265) | 3x 4K30 (H.265) | 6x 1080p60 (H.265) | 12x 1080p30 (H.265)
1080p30 supported by 1-2 CPU cores
Video Decode
1x 8K30 (H.265) | 2x 4K60 (H.265) | 4x 4K30 (H.265) | 9x 1080p60 (H.265) | 18x 1080p30 (H.265)
DL Accelerator
2x NVDLA v2
Carrier Board
Storage
1x M.2 Key M PCIe (M.2 NVMe 2280 SSD 128G included)
I/O
Ethernet
1x RJ45 GbE (10/100/1000M)
4x RJ45 GbE PoE(PSE 802.3 af 15 W, 10/100/1000Mbps)
USB
4x USB3.1 Type A, 2x USB2.0 Type C
DI/DO
4x DI, 4x DO, 3x GND_DI, 2x GND_DO, 1x GND_ISO, 1x CAN
Display
1x HDMI 1.4
Fan
1x 4 pin Fan Connector (5V PWM)
COM
1x DB9 (RS232/RS422/RS485)
SATA
2x Drive Bays to support 2.5" SATA HDD/SSD(SATA III 6.0Gbps)
SIM
1x Nano SIM card slot
Button
Reset Button, Recovery Button
Expansion
RTC
1x RTC 2-pin, supports CR1220 but not included
Mini PCIe
1x Mini PCIe for LoRaWAN®/4G/Series Wireless (Module optional)
M.2 Key B
1x M.2 Key B (3042/3052) support 4G/5G (Module optional)
Fan
Fanless, passive heatsink; 1x Fan connectors(5V PWM)
TPM
1x TPM 2.0 connector (Module optional)
Power
DC 12V-36V Terminal block 2 pin
Mechanical
Dimensions (W x D x H)
194.33mm x 187mm x 95.5mm
Installation
Desk, DIN rail, VESA
Weight
2.8kg
Operating Temperature
-20 ~ 60°C with 0.7m/s
Operating Humidity
95% @ 40 °C (Non-condensing)
Storage temperature
-40 ~ 85°C
Storage humidity
60°C@ 95% RH(Non-condensing)
Vibration
3 Grms @ 5 ~ 500 Hz, random, 1 hr/axis
Shock
50G peak acceleration (11 msec. duration,eMMC,microSD,or mSATA)
Warranty
2 Years
用途
Lumeo currently powers a wide range of use cases for large retail malls, parking facilities, commercial buildings, and critical infrastructure installations. Lumeo makes it easy to track occupancy; monitor traffic flow; check vehicle speed; recognize human faces, license plates, and vehicle makes/models; and identify loitering, crowd gathering, and line crossing.
Find more solution: lumeo.com/solutions
部品リスト
reComputer Industrial
x1
Mounting bracket
x2
DIN rail bracket
x1
Bracket screw
x4
16-Pin Terminal Block for DIO
x1
19V Power adapter (power cord sold separately)
x1
2-Pin Terminal block power connector
x1
Lumeo AI Gateway powered by reComputer Industrial Jetson Orin
SKU B802000101
Easily build, and manage custom video analytics applications with Lumeo’s intuitive no-code platform equipped with drag-and-drop tools and pre-built analytics, reducing development time from days to minutes. Deploy instantly to the edge using this Lumeo AI Gateway powered by reComputer Industrial Jetson Orin device.
This bundle has been discontinued
USD$0.00
オプションを1つ以上選択してください
